Repairs 1822 Hydro, I'm going to try fixing. Tips?
jjk212
Hi,
I have the Right Hydro out and drained, still has the nylon cooling fan attached(along with the coupler that the fan attaches to). Any tips on how to get that fan assembly off? I have the 2 set screws removed, but the thing is not moving. hoping someone has a nice trick to getting it off.
I plan to use a fat rubber band to keep the 4 main bearings in their respective holes. Then make absolutely sure to mark each one and their respective hole when I do remove so thouroughly clean the parts and make sure all parts / holes are super clean
Does anyone have any tips on a source for new seals? Tips on how to prime the pump.
Thanks,
John
