I have a 10HP Briggs and stratton engine on an emergency generator. It is Model #19G412 and has a Walbro 5-4993 carb.
The only way i can get it to start is to put gas in the spark plug hole. Once it starts up, it will start again as long as it is still warm. I have cleaned the carb twice. The choke closes all the way but will not put gas in the cylinder. Also the carb is tight without any vacuum leaks. It has a fuel pump and the tank is above the carb. Any help will be appreciated.
