need help, got this mower,don't know why. The lady said she didn't know what was wrong with it. I have been looking at fixin it and I need help the starter has a solenoid attached at bottom of starter motor but also has one on frame on right side. I replaced the 1 on frame before I saw the other 1. I get 12 volts out of new solenoid which trying to start engine and power from switch to new 1 is good. Why 2 solenoids and how do they work. Do you think someone may have added the 1 on frame. Should I remove it and run wiring to the 1 on starter motor. Any suggestions or answers will be appreciated.
