Best blades for bagging??
Pnlawncare
Have a 48" lesco wb with gator blades on it. I was wondering which is the best for cutting and colleting grass? Hi lift? Let me know thanks!
KennyV
Hi lift blades move more air... If your bagging system will allow for a lot of air movement, (most require it), that will be your better choice.... :smile:KennyV
Pnlawncare
Ok so hi lift will be good to collect grass in my standard metal "bag". Now are gators blades best used for mulching leaves? Thanks ken appreciate all your helpful input in the forums.
Carscw
Gator blades are the best for mulching leaves but not good if grass is tall and thick
Sent from my iPhone using LMF
If you are cutting dry gator blades are the best out there for all types of cutting and bagging.
