I have an older John Deere hydro 185. I am a woman so I admit up front that I know nothing about small engines. However, I am a do it yourselfer and will try to fix things if I can do so. Recently it would not start, I was told that it needed a new starter and battery and I changed these out myself.
Now the mower deck pulleys and belt are very slow to turn so it won't mow. They will start out turning fine when I flip the PTO switch on, but then they slow down and eventually stop so I can't mow anything at all. Someone told me that it was the PTO switch, so I replaced it. It wasn't the switch apparently, because it still does the same thing. I start it up, turn on the switch, I can see the pulleys and belt turning but then they slow down and stop altogether.
I am desperate to get my yard mowed. It is knee high now. I can't afford the high landscaping prices around here and I would rather use that money towards getting my mower repaired. I am unemployed so money is tight.
Any ideas on what it could be? Someone said it was the mower deck pulleys but there are quite a few of them on the mower deck, so how would I determine which one is not working right? I am not that great a fan of taking the mower deck off the mower and putting it back on. As a woman, it is too heavy for me to handle on my own.
