Hi to all,
I have an HR215 with a broken drive shaft. The mower works perfectly, and I just haven't had the time to fix the drive shaft.
What I'd like to know regards the gear box. There are times when the mower can be pulled back and it rolls, while other times, the gears lock up and won't allow it to roll backwards. Why would this be intermittent, and is there a way I can temporarily make it roll backwards all the time until I get the shaft repaired?
Thanks a lot for considering my questions!
