Re: Hello to all: Craftsman 42" Lawn Tractor (starter) didn't pull the flywheel !
Bob
I am trying to remove the starter from my Briggs&Stratton 20hp Intek V-Twin. I just asked this question before I saw your message. How did you get it off? I need to have it tested.
Thanks
Hello carlb43: good to hear from you. I will get some notes together and a pic if I can find them. As I'm not familiar with this sites conversational formats it might be a good idea if you used my email (bmcauliffejr@yahoo.com).
Just in case we loose touch; as I recall there are two bolts on the top of the starter. One is covered and difficult to get to. I found that a long box wrench (? 1/2) could be inserted under the covering. When you go in this way, you have enough swing to break the bold and move it out in small increments.
There is "just enough" clearance to back the bolt out and miss the overhang.
Hope this helps Carl B/ Bob
