Just picked up a 99 928d yesterday. The hydraulic lift isn't working and I'd like to see if anyone has any ideas. Ive checked the fuse and run the wiring from the handle to up under the fuse box to make sure it's plugged in.
I have a voltmeter, if someone could tell me if this should have power to one side switch all the time or just power to relay, or exactly where to check for incoming power to pinpoint where the problem is? Thanks
