My 727 powered mower deck will not lift up. I push the on power up button but all it does is make a ratcheting noise,Help:confused2:
On my 725, if I am adjusting the cutting height, the up/down switch works O.K. However, if I want to raise the whole deck to inspect or sharpen the blades, it is necessary to hit the DOWN button. keep holding the down button and when it has reached the lowest point, then the deck starts to raise. You also have to manually hold up the positive height adjustment lever while doing this. Not trying to insult your intelligence, but if you are new to the mower, this is necessary.
