Not exactly a repair question but a parts or method question.
BobW496
  • / Not exactly a repair question but a parts or method question.
How do I connect a scag turf tiger to a tow-Behind DR Leaf and Lawn Vacuum. I need to find a way to connect the DR to the discharge chute of the Turf Tiger 61 inch deck. Has anyone done this before?
I want to buy the DR Leaf and Lawn vacuum, if this can be done.
lostinbaja
Give Trac-Vac a call Trac Vac Outdoor Lawn Vacuum, Leaf Vacuum & Grass debris Lawn Vac They make chute adapters for most mowers to fit their lawn vacuums.
IMHO, I think the DR unit has too much plastic on it. I have had issues with the plastic on my Agri-Fab unit cracking and needing replacement after a few years of use. The plastic is not cheap. I'm a big fan of the Trac-Vac units....they are all steel.
