Results 1 to 5 of 5
  1. #1
    Join Date
    Jun 2012
    Posts
    5
    Location
    Ohio
    Mower
    Hustler Sport
    Hustler Sport - Deck Removal, Blade Maintenance
    I just had my 42 inch Sport delivered. After studying it and the manual, I am a little dismayed about all the commentary about sharpening the blades daily (I do not expect to do - level ground) and there being no apparent easy means to remove the deck or blades for maintenance. The manual does not seem to offer much help in this area other than working from below the machine. Any recommendations?
  2.
  3. #2
    scott47429's Avatar
    Join Date
    May 2012
    Posts
    646
    Location
    Indiana
    Mower
    Exmark
    Re: Hustler Sport - Deck Removal, Blade Maintenance
    the deck on my mower is way to heavy for me to remove by myself so i went a bought a lawn mower jack and use it to remove blades and clean out the deck 2 times a year
  4. #3
    Join Date
    Mar 2012
    Posts
    5
    Location
    Indiana
    Mower
    16 GTH with 50" deck
    my brother has the same mower and only sharpens the blades 2-3 times a season. he pulls it up on those portable car ramps
  5. #4
    Join Date
    Aug 2012
    Posts
    16
    Location
    Mississippi
    Mower
    Hustler
    Quote Originally Posted by Carl53 View Post
    I have a Sport 48" and put a small one ton chain hoist in the ceiling of the shop then use an electric impact wrench; that works great.
    Love the Hustler. I hope you didn't get the Honda GVX530. Mine is down for the 4th time for valves under warranty. Carb trouble as well. Spends more time in the shop than home.
  6. #5
    Join Date
    Sep 2012
    Posts
    11
    Location
    Louisiana
    Mower
    Hustler Sport 48Inch
    I run mine up on one plastic ramp I got a pair of at Wal-Mart. If you do it sideways an d run one front wheel up the ramp, the ramp doesn't even get in the way. I use a 2X4 and a box-end wrench and get the blades off very handily, no problems. The blades are heavy and I have never bent one. Typical blades: sand will wear them, and you have to sharpen them, but they are reasonably priced I think at about $42 for all three (48 inch).
    I can't see how it could be much easier or better.
Similar Threads
  1. Hustler Sport - to buy or not
    By tfarrell in forum Hustler Forum
    Last Post: 09-28-2012, 09:24 PM
  2. Hustler Sport Transmission cooling fan.
    By SkrogPappa in forum Transmissions & Transaxles
    Last Post: 06-02-2012, 01:11 PM
  3. Blade adapter removal / Blade changing questions
    By offensive_jerk in forum Lawn Boy Forum
    Last Post: 04-26-2012, 01:32 AM
  4. Hustler Sport 42
    By horse in forum Hustler Forum
    Last Post: 06-24-2011, 01:37 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
