Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    May 2012
    Posts
    Location
    Louisiana
    Mower
    Bob-Cat
    Carburetor problem? 25 hp Kawasaki
    I have a 2001 25 hp Kawasaki engine on a bobcat mower. It runs great when the blades are not engauged but when i engauge the blades it runs great for 30 minutes then it dies. It restarts and I run it for a few second then dies. It just keeps dieing, it seems to me like it's not getting fuel...I check the tank cap it's open, the fuel filter is new, I check the fuel pump and it's has a good stream . The only thing I can figure its the carburetor. Ive even tried seafoam and nothing it still does it. Any suggestion ?
  2.
  3. #2
    Edwards saw service's Avatar
    Join Date
    Jul 2011
    Posts
    74
    Location
    Pennsylvania
    Mower
    We have this problem come into the shop with older bob cats. How many hours are on the unit? It may be time for the heads to be replaced or the valves to be lapped.
    Edwards Saw Service in Glen Mills PA
  4. #3
    Join Date
    May 2012
    Posts
    Location
    Louisiana
    Mower
    Bob-Cat
    Re: Carburetor problem? 25 hp Kawasaki
    The mower has over 2000 hours but the engine has less than 200 hour.
  5. #4
    Join Date
    Apr 2012
    Posts
    671
    Location
    Texas
    Mower
    I'm sure you already know this but an engine needs the right amount of air, the right amount of fuel, compression and spark at the right time to operate properly. If one of the above factors are missing or in the wrong proportion the engine will not run or may run poorly. When the symptom is present find out which one(s) is/are missing from the equation.
  6. #5
    Join Date
    Jun 2011
    Posts
    570
    Location
    Knoxville, TN
    Mower
    Cub Cadet Zero Turn
    It doesn't take much to get an engine to run erratically. One would think that less than 30 minutes would be enough to cause an intake valve with insufficient gap to heat up enough to come off its seat. Wouldn't hurt to go through the carburetor and give a good cleaning with carburetor cleaner and re-assemble. Enrichen the mixture screw some couldn't hurt. Too much and it would blow black smoke~~~ I'd take the valve cover off and look at the gaps and see what they are set at.
  7. #6
    Join Date
    May 2014
    Posts
    Location
    New York
    Mower
    Quote Originally Posted by HBA View Post
    i had the exact same problem with my 25hp kowasaki. i would mow for half an hour fine then it would quit. it would restart with the choke pulled half way out but run rough. local mecanics were convinced it was a fuel problem. after cleaning the carb, eliminating ethenol, changing plugs, replacing fuel filter and pump, turns out the problem was an ignition coil. it would break down when it got hot. i replaced both at a cost of $95 and a couple hours. hope this saves you the agrivation i went though.
  8. #7
    FloGro's Avatar
    Join Date
    Apr 2014
    Posts
    33
    Location
    Florida
    Mower
    I would definitely check to see if it has spark after it gets nice and hot and shuts off, it sounds like a classic ign coil problem because it runs so long before shutting off, if it were fuel related it would shut off alot sooner. Fuel cap venting properly is something to consider too
  9. #8
    Join Date
    Nov 2012
    Posts
    242
    Location
    New York
    Mower
    Ferris
    Quote Originally Posted by FloGro View Post
    I think he said the cap was ok. I agree with the bad coil and it's an easy thing to check. gregjo1948
  10. #9
    Join Date
    Feb 2017
    Posts
    Location
    United States
    Mower
    A friend of mine had a very similar problem with his riding mower. The problem was traced back to bad ignition coil.
  11. #10
    Join Date
    May 2017
    Posts
    Location
    New Jersey
    Mower
    Bob-Cat
    I have replaced all the parts listed. I would like to know what the fuel pump is called. I dont think its called a fuel pump but if you were to trace the fuel line fron the carb this is the first gadget that fuel line connects to.
    If I were to reverse the diagram it would be something like this:
    Fuel lines from Fuel tanks to the fuel shut off switch.(At this point you can choose which tank you want fuel from.
    Then from fuel shut off switch to the (Fuel pump ????) This gadget is black, round and has fuel line ports which one port goes to the carb.
    Thats it in a nutshell. Any help would be appreciated.
    Thanks Marty
Similar Threads
  1. Kawasaki FB460V
    By jakesmurray in forum Kawasaki Engine Forum
    Last Post: 05-01-2015, 10:29 AM
  2. Kawasaki or Kohler????
    By coltscardinalsfan in forum Mower & Equipment Buying & Pricing
    Last Post: 09-01-2014, 11:52 AM
  3. Kawasaki Carb
    By JDMATT in forum Kawasaki Engine Forum
    Last Post: 04-03-2012, 12:55 AM
  4. Tire Pressure on 2001 33" RER?
    By gitnby in forum Snapper Forum
    Last Post: 10-10-2011, 11:44 PM
  5. 2001 Kubota G1800 For Sale
    By Kubota_Diesel in forum Kubota Forum
    Last Post: 09-08-2011, 09:19 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
