Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. #1
    txzrider's Avatar
    Join Date
    Apr 2012
    Posts
    389
    Location
    Texas
    Mower
    Country Clipper
    what really defines commercial vs residential?
    So I am still new to the forum, I am constantly amazed at the amount of expertise and experience that is displayed here! I recently bought a new mower(used with low hours from craigslist). I did alot of research looked at specifications until I was blue in the face... finally went with what appeared to be a huge upgrade to my snapper zrider, yet also gave me something similiar and something new I learned I needed after 15 years with the snapper. I recently read a comment about commercial vs residential quality that made me wonder...
    What really defines it? Price paid? Size, quality of materials?
    I think is has to be expected life cycle, durability and ease of repair. As well as what I really think it is all about, the ability to get a good clean cut. So what defines that? Well to me has has to be blade speed with sharp blades and a stable deck that keeps everything in alignment. Supported by a strong chassis that allows the deck to float at a uniform height. So bottom line I think any mower can cut as well as any other mower given the same blade speeds, blade sharpness and uniform height above the grass. My new mower is a huge upgrade, has blade speeds approaching what I have seen for commercial and this years version does. I still think of it as residential due to the things I would expect from a commercial mower... a top grade air filtration system, a better engine, mine is a 20hp B&S single cylinder, much stronger hydros. So I am asking all of you who are recommending someone spend $5k and up (admittedly below real commercial) what are you expecting to get with those dollars and why? How will it help the guy that has 4-6 acres to mow and that is all.
    Country Clipper Jazzee 2038BSG-SR110 , Snapper FRP 216012, Cyclone Rake, retired Snapper Zrider yz1333.
  2.
  3. #2
    Join Date
    Apr 2012
    Posts
    Location
    Minnesota
    Mower
    1972 Cub Cadet 127 (from my Dad)
    Re: what really defines commercial vs residential?
    I see you have not gotten any responces to this. Maybe there are not many commercial readers on this forum.
    I would say...
    1. the engine would not be a briggs and stratton, it would be a Kawi, Kohler or Diesel
    2. the deck would not be stamped, it would be constructed and welded
    3. the deck width would be 50+ inches, although I have seen 44" comercial units. This depends on lot size
    4. servaceable parts like the greese zerts in the area that would wear on a residential mower
    5. the unit is identified by the manufacture as commercial
    6. the unit is not covered by plastic housing
    7. when you hop on it a little foice in your head says "arugh, arugh, arugh!!" and you have to increase your cap size by a notch or two.
    MN Ben
    resident looking for a comercial mower
    My signature sucks......
  4. #3
    Sprinkler Buddy's Avatar
    Join Date
    Apr 2011
    Posts
    289
    Location
    Florida
    Mower
    60" 30 HP Hustler's
    Love the post before mine. Lol
    A residential mower will cut 6 acres just fine, if that's all it's having to do. Work that residential mower 40-60 hrs a week during the growing season, chances are you wont have much of a mower left after
    1- 2 yrs.
    Commercial mowers are better suited for continuous use which for commercial lawn care guys, that's a must.
    "This is such a Great Quote, I had to borrow it from a TBN member."
    "You can easily judge the character of a man by how he treats those who can do nothing for him."
    ~ James D. Miles
  5. #4
    txzrider's Avatar
    Join Date
    Apr 2012
    Posts
    389
    Location
    Texas
    Mower
    Country Clipper
    thanks for the replies... I did not think anyone ever would. So what about quality of cut? Is that only higher blade speed that the commercial units can do... or do the pro guys keep their blades extra sharp. That was always an area where I felt like I should be sharpening much more often. By the way I heard a diesel TORO ZT cruise by while dropping my son off at school and I was letterally shocked how quiet it was!
  6. #5
    Join Date
    Apr 2011
    Posts
    289
    Location
    Florida
    Mower
    60" 30 HP Hustler's
    Using sharp blades defiantly improves the quality of the cut no matter the machine used. Residential mowers give just as good a cut when blades are properly maintained and the yard is cut on a regular bases. A push mower gives the best cut of all but isn't practical for us commercial guys or anyone with a big yard. Lol
    The commercial mowers give a better cut than residential mowers on lawns that haven't been kept up. Simply because they have more HP to push through the thick stuff.
    The diesel mowers have come a long way. They work best on harder ground, with their added weight they tend to leave a rut after awhile on soft lawns like we have here in FL.
    ~ James D. Miles
  7. #6
    Parkmower's Avatar
    Join Date
    Jun 2011
    Posts
    891
    Location
    New York
    Mower
    Cub cadet, Jacobsen, Husqvarna, toro
    I run commercial mowers for a living. On a commercial mower everything is just built way heavy dutier. The engine, hydro pumps, hydro lines, deck spindles, even the seat. I am somewhat amazed at how flimsy residential mowers are.
  8. #7
    Join Date
    Apr 2011
    Posts
    289
    Location
    Florida
    Mower
    60" 30 HP Hustler's
    Quote Originally Posted by Parkmower View Post
    True that! That's why our mowers can handle the abuse we put them through.
    ~ James D. Miles
  9. #8
    Join Date
    Mar 2011
    Posts
    881
    Location
    Washington
    Mower
    honda 1031, cub cadet 2164, jacobsen park 30, simplicity
    Post Re: what really defines commercial vs residential?
    I think the longevity of the machine probably defines the demarcation between commercial and residential machines. I've seen some nice looking lawns that were cut by cheap machines, but in 200 hrs. (or less!) of use, that cheap machine will be junk. Stepping up to a better built machine ended up saving me a lot of time and money that I didn't spend at the repair shop at $59.00/hr.
  10. #9
    1,000 Post Club
    BKBrown's Avatar
    Join Date
    May 2010
    Posts
    1,415
    Location
    Virginia
    Mower
    VENTRAC
    As stated in the thread - commercial machines are generally rated and designed for use on a continuous basis with hard use and long life. Residential machines are designed to be used less frequently and generally have a shorter expected life unless treated gently and caringly maintained.
    Quote Originally Posted by MNBen View Post
    I would say...
    1. the engine would not be a briggs and stratton, it would be a Kawi, Kohler or Diesel This is the one I can't agree to - Briggs also has commercial engines - you just don't want a Briggs designed for residential units on a commercial machine. Whatever brand engine - it should be designed for commercial use, matched to usage, and maintained well.
    MN Ben
  11. #10
    2,500 Post Club
    Join Date
    Aug 2011
    Posts
    2,500
    Location
    Washington
    Mower
    Interesting to read these comments. What is the entry level in liquid cooled engines. I am still stung by the overheated time bomb BS Intek 24 that came apart twice during reasonable use and TLC.
Similar Threads
  1. Are residential zero turns worth it???????
    By Rpeter1 in forum Mower & Equipment Buying & Pricing
    Last Post: 06-02-2012, 12:00 PM
  2. Replies: 5
    Last Post: 05-25-2012, 03:55 PM
  3. Residential Wind Turbines
    By AndyMan in forum The Front Porch
    Last Post: 03-23-2012, 06:09 PM
  4. first time residential purchase! budget help please!
    By samoset in forum Mower & Equipment Buying & Pricing
    Last Post: 03-16-2012, 08:48 PM
  5. Residential market ride-on
    By Twinkle in forum John Deere Forum
    Last Post: 01-03-2011, 08:49 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
