Results 1 to 7 of 7
  1. #1
    Join Date
    Apr 2012
    Posts
    Location
    Canada
    Mower
    Briggs 3.5 hp Classic
    I have a mower as stated above, Model 9D902 Type 2005B2 Code 0111155
    I need guidance in setting up the carb linkages/springs. When running the motor idles good, at high idle the rpm increases but I can hear a soft backfire. I removed the air cleaner and when I move the throttle lever clockwise I get a better rpm.
    This makes me think I connected the linkages incorrectly. This motor is off a lawn mower (yes I changed the flywheel) and does the job good. A good picture reply is appreciated.
    Thank,
    Dave
    Attached Images Attached Images
  2.
  3. #2
    Parkmower's Avatar
    Join Date
    Jun 2011
    Posts
    891
    Location
    New York
    Mower
    Cub cadet, Jacobsen, Husqvarna, toro
    Not sure what your asking. I have a 3.5 classic that I'll take some pics if you need.
  4. #3
    Join Date
    Apr 2012
    Posts
    Location
    Canada
    Mower
    Re: Briggs 3.5 hp Classic
    I want to know if I have the carb springs/linkages conected correctly.
  5. #4
    Parkmower's Avatar
    Join Date
    Jun 2011
    Posts
    891
    Location
    New York
    Mower
    Ok. From your pic they don't look too bad to me. But I'm not 100%. I'll look at mine tomorrow and see if it'll help any. .
  6. #5
    Join Date
    Apr 2012
    Posts
    Location
    Canada
    Mower
    Hi again,
    I found a diagram for my carb (#52) in attachment. I also found out where the extra spring goes...
    My next question is: when running the motor I hear a very faint or soft backfire/missing. Any suggestions on how to eliminate this?
  7. #6
    1,000 Post Club
    pugaltitude's Avatar
    Join Date
    Jan 2012
    Posts
    1,141
    Location
    Scotland
    Mower
    Lots
    Quote Originally Posted by buster01 View Post
    Hi again,
    What exhaust is fitted to it as I cant see on the pictures.
    If its a round one and it sounds like a "putt" noise now and again then its the just the normal sound of the engine.
    They changed the exhaust to a rectangle low tone exhaust to try and sort this noise.
    The "best" engine you will ever own!
    Briggs & Stratton MST.
  8. #7
    Join Date
    Apr 2012
    Posts
    Location
    Canada
    Mower
    It has the round exhaust.
Similar Threads
  1. Buying Advice Dixie Chopper...Classic T or Classic W??
    By target75 in forum Dixie Chopper
    Last Post: 09-19-2012, 01:56 PM
  2. Classic, collectible, vintage
    By benski in forum Polls
    Last Post: 10-07-2011, 10:35 AM
  3. Classic
    By sss in forum Polls
    Last Post: 09-24-2011, 06:57 PM
  4. a classic?
    By reddragon in forum Mower & Equipment Operation
    Last Post: 09-03-2011, 04:22 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
