Results 1 to 2 of 2
  1. #1
    Join Date
    May 2012
    troy built mower 6.75 series 190cc
    Lawnmower sometimes starts up and then dies down. Revs up and runs good until i run it over grass and then it dies down to a very low idle level. Finally it would pick up to a high level and run good for about 5 minutes and then die down and just cut off. now it won't start.
    I replaced the spark plug, fuel filter screen, removed old gas that was in there from when i bought it at a pawn shop and put in new fuel and gas cleaner. The oil is very new. It won't start up now. Does this lawnmower have a gas filter as well as a fuel screen? Any help appreciated.
  3. #2
    Join Date
    Apr 2012
    Re: troy built mower 6.75 series 190cc
    Sounds like fuel starvation due to the old gas that was sitting in it from the pawn shop. I'd start by removing the carburetor and giving it a good cleaning and replacing any defective part/gasket. Youtube has a lot of information on rebuilding/cleaning small engine carburetors and is a good place to start if you have never rebuilt a carburetor before.
    Did you try spraying some aerosol carburetor cleaner in the carburetor to see if it would start on the cleaner? If you spray some cleaner in the carburetor and the engine starts & runs for a second or two then dies it is fuel starvation and the main jet is most likely plugged.
Similar Threads
  1. Troy Built Mower Sputtering - Help!
    By concort in forum Small Engine & Mower Repair
    Last Post: 07-21-2012, 05:18 PM
  2. Troy Bilt Briggs and Stratton 675 190cc engine acting funny
    By alan.jim in forum Briggs & Stratton Forum
    Last Post: 04-08-2012, 11:22 PM
  3. Troy built cultivator
    By 0303maz in forum Troy-Bilt Forum
    Last Post: 01-05-2012, 09:41 PM
  4. thinking troy built think again
    By jd335 in forum Mower & Equipment Buying & Pricing
    Last Post: 10-13-2011, 07:28 PM
  5. used Troy built tractor
    By Spawn0097 in forum Troy-Bilt Forum
    Last Post: 07-10-2011, 12:02 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
