dnoonkeste
- Nov 8, 2010
- Threads
- 11
- 11
Does anybody have a diagram of the linkage on a tecumseh 10 hp carburetor?
No, I don't have a diagram, but remember the SOLID link goes from GOVERNOR arm to THROTTLE SHAFT. The SPRING goes to THROTTLE CONTROL ARM. Spring tension pulls engine INTO fuel. Governor pulls it OUT. Engine speed is determined by tension on spring (YOU giving it more gas) and the GOVERNOR trying to pull it out. Resulting balance between those two forces results in engine RPM. Hope it helps some.
Tecumseh had way too many variations to give you a decent response without an engine/spec. number........
