View Poll Results: which string trimmer do you own
Voters
68. You may not vote on this poll
  • 2 cycle
    52 76.47%
  • 4 cycle
    16 23.53%
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Join Date
    Mar 2012
    Posts
    Location
    Indiana
    Mower
    Conquest
    2 cycle vs 4 cycle string trimmer
    Post what you got, how long you've had it and the maintenance performed.
  2.
  3. #2
    Join Date
    Mar 2012
    Posts
    Location
    Indiana
    Mower
    Conquest
    Re: 2 cycle vs 4 cycle, straight/curved string trimmer
    I've had the troybuilt 4 cycle for nearly 10 yrs....straight shaft and is still humming along. Despite what I've read in reviews, it's been great! It is wearing out a bit and starting my "painful" search for another. Wanting to get opinions here. 4 cycle has been easy to use and plenty enough power for my bi-weekly 2 acre lot.
  4. #3
    talley2191's Avatar
    Join Date
    Mar 2012
    Posts
    78
    Location
    Maryland
    Mower
    John Deere X300
    2 cycle Shindaiwa that I got from a buddy in 2004 a he was getting a new one. He used it commercially and I have used it weekly for 10-15 minutes a time since. Fuel is the only maintenance lol. I have not even changed a spark plug. Prime it 6 times pull twice while the choke is on, turn the choke off and pull once and she fires up. Been starting her like that for 8 years. Love it!!!
  5. #4
    Grass ala Mowed's Avatar
    Join Date
    May 2010
    Posts
    207
    Location
    Suffolk Virginia
    Mower
    Toro Super Recycler with Kohler engine
    Re: 2 cycle vs 4 cycle string trimmer
    Can't add too much, I had a Ryobi 2 stroke I liked that was basically fuel, plug every other year, clean the air filter every year. I forget what happened to it, but I bought another Ryobi and I don't like it, NO air filter and the carb cover flies off if you hit the choke lever a little too hard. Somewhere on here is a post about single bearing (think the old Cox .049 model airplane engines) and two bearing engines. Apparently if the starter is on the shaft side of the engine it's likely a single bearing. As I've said before, I old enough to spend a little more for what I really want and given my local dealer that is excellent, I'll likely buy a Stihl or Echo, whichever feels better (they sell both).
  6. #5
    Join Date
    Mar 2012
    Posts
    23
    Location
    Michigan
    Mower
    Toro
    I have a Shindaiwa M242. 23.9cc 2-stroke. I have had it about a month, ~3 hours on the engine. I run 50:1 Husquvarna 2 stroke oil mixed with premium and the thing blows me away every time. I have a half acre corner lot with steep, deep ditches so I do a fair amount of trimming once a week. Nothing near the commercial capability of the Shindaiwa but I am in no way unhappy with it.
    Toro Super Recycler (Evil Chinese Motor)
    Other garage highlights:
    Shindaiwa M242 Multitool (trimmer), Husqvarna 460 Rancher (Chainsaw), Craftsman 2 stage auger/blower 6hp Tecumseh
  7. #6
    Join Date
    May 2011
    Posts
    225
    Location
    Inside the Beltway in Virginia
    Mower
    Old Honda HRS-21
    I've had a Troybilt 4 cycle for 5 or 6 years. I've changed the oil and spark plug regularly, and adjusted the valves a couple times. Runs great.
  8. #7
    5,000 Post Club
    lawn mower fanatic's Avatar
    Join Date
    Jun 2012
    Posts
    6,759
    Location
    Pennsylvania
    Mower
    Two Honda HRX217HYA's and an HRR216TDA
    I have the Echo 2-cycle string-trimmer. I got it a few months ago, and I use it commercially. Love it!! No maintenance needed so far!
    2013 4x6 custom utility trailer
    Honda HRX217(3)HYA mower
    Honda HRX217(5)HYA mower
    Honda HRR216TDA mower
    Echo SRM-225 trimmer
    Echo GT-2100 trimmer
    Echo PB-770T backpack blower
    Echo PB-255LN handheld blower
    Echo PE-225 edger
    Craftsman 24" 179cc dual-stage snow blower
    Black and Decker 22" electric hedge trimmer
  9. #8
    1,000 Post Club
    Briana's Avatar
    Join Date
    Jul 2010
    Posts
    1,550
    Location
    California
    Mower
    Looking to Buy :)
    Great poll...
    I thought this thread might be helpful to other members who may not be mechanically savvy :
    The Difference Between 2 Cycle and 4 Cycle Engines
  10. #9
    Join Date
    Apr 2012
    Posts
    82
    Location
    Australia
    Mower
    JDLT155x2/JD415/Deutscher Tractors16-600hp/Farm/Earthmoving Equip
    2 Strokes only - 1x Shindawia angle shaft c.20yrs old, 5x Stihls commercial straight shaft c.1-8yrs old, 3x Cheap Chinese straight shafts 1-3yrs old - all running fine, original plugs, no rebuilds & normal maintenance only cleaning air filters, lubricating shaft/bearings..etc..
    All run on 50:1 Husqvarna or Motul 2 stroke oil & 98 RON unleaded (i.e. no ethanol)
    Why 2 stroke only ? Better power to weight, simpler/cheaper to maintain or if required to rebuild & more critically constant lubrication at the acute/various angles trimmers/brushcutters are used.
  11. #10
    Parkmower's Avatar
    Join Date
    Jun 2011
    Posts
    891
    Location
    New York
    Mower
    Cub cadet, Jacobsen, Husqvarna, toro
    2cyl only way to go with trimmers.
    I've got a weedeter featherlite thaty mom bought and then gave to me when I bought my first place. It's goin on 20 years old. Cleaned carb and new fuel lines a few years ago.
    Also have a hoffco jp140c straight shaft. It's about 15 years old. Only cleaned carb.
    At work we run Stihl fs 55's and love them. I recommend this trimmer to everyone after seeing the abuse these take and keep going.
    Always run out of fuel at end of season.
Similar Threads
  1. how a 4 cycle works
    By reddragon in forum Mower & Equipment Operation
    Last Post: 07-25-2012, 11:33 AM
  2. Troybilt big red 4-cycle trimmer problem
    By Slowride in forum Small Engine & Mower Repair
    Last Post: 04-20-2012, 06:40 PM
  3. Amsoil 2 cycle mix
    By Fireman 123 in forum Mower & Equipment Operation
    Last Post: 11-18-2011, 12:51 PM
  4. 2 cycle mower
    By reynoldston in forum Mower & Equipment Operation
    Last Post: 08-06-2011, 12:19 AM
  5. Buying Advice 4-cycle trimmers
    By Opposed twin in forum Mower & Equipment Operation
    Last Post: 05-13-2011, 08:16 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
