Results 1 to 9 of 9
  1. #1
    1,000 Post Club
    davbell22602's Avatar
    Join Date
    Nov 2011
    Posts
    1,273
    Location
    Bunker Hill, West Virginia
    Mower
    Cratfsman Gt3000 and gt5000
    Poulan Pro Wiring Harness Help
    Fridgadaire
    M- pr185h42st
    S- 033100 c 012638
    MFG ID - pr185h42sta
    18.5 Intek Briggs, 42in hydro
    I got this not running. The PO pulled all pins out of the connector going the key switch. I'm unsure where the blue, double black wire and double black goes. Pins G, M, and B are still empty.
    I tried using the wiring schematic form this model but colored wires dont match up. pr18542stc
  2.
  3. #2
    Join Date
    May 2010
    Posts
    5,201
    Location
    Illinois
    Mower
    kioti/rhino finish mower
    Re: Poulan Pro Wiring Harness Help
    ILLINOIS ENGINE, BEECHER CITY, IL
    BRIGGS AND STRATTON MST (MASTER SERVICE TECHNICIAN)
    Sales and Service for Dolmar/Makita, Poulan, Briggs and Stratton, Kohler, Lauson(Tecumseh, LCT), Brute, Honda, Subaru
    Warranty service for MTD, Murray, Karcher, Earthquake, Yamaha engines, American Landmaster, Worx, Rockwell Tools, Great Lakes Technologies products(Wen, CZ), Efco, Generac portable/DR power and others.
  4. #3
    1,000 Post Club
    Join Date
    Nov 2011
    Posts
    1,273
    Location
    Mower
    Same diagram as what I'm working with now. Thanks anyways.
  5. #4
    Join Date
    Apr 2012
    Posts
    28
    Location
    Texas
    Mower
    I repair all of them
    it looks like the diagram is ayp.. it will fix your problem..
  6. #5
    1,000 Post Club
    Join Date
    Nov 2011
    Posts
    1,273
    Location
    Mower
    So which hole does the blue wire go to in the connector for the ignition switch?
  7. #6
    Join Date
    Apr 2012
    Posts
    28
    Location
    Texas
    Mower
    Quote Originally Posted by davbell22602 View Post
    I have the color code and where all the wires go leading from the starter key switch, to the connector.. and the wires coming from the engine to the back side of the connector.. the diagram is at my shop.. will be there tomorrow after 1:00pm.. customer coming to pick up his craftsman.. what what size is your engine.. feel free to call me at 1 832-329-2778..
  8. #7
    1,000 Post Club
    Join Date
    Nov 2011
    Posts
    1,273
    Location
    Mower
    Here's pic of what colored I have.
  9. #8
    1,000 Post Club
    Join Date
    Nov 2011
    Posts
    1,273
    Location
    Mower
    Quote Originally Posted by Lawnmowerman2 View Post
    18.5 vtwin briggs intek hydro 42 inch
  10. #9
    1,000 Post Club
    Join Date
    Nov 2011
    Posts
    1,273
    Location
    Mower
    Got this running but it will stay running when the parking brake is on. When I release the parking brake and clutch pedal the mower dies. I guess thats bad clutch pedal switch. It will start with the key in park. Found a fuse that came out in 2 pieces. The guy said he thought the fuel solonoid was bad. Also the battery is bad as it will only start with a 740 amp jumper start box.
Similar Threads
  1. Need Help Installing New Wiring Harness
    By davbell22602 in forum Small Engine & Mower Repair
    Last Post: 03-25-2012, 10:29 AM
  2. Poulan/Poulan Pro/Weedeater warranty
    By ILENGINE in forum Poulan Forum
    Last Post: 02-20-2012, 05:00 PM
  3. Poulan Pro
    By jacko in forum Mower & Equipment Buying & Pricing
    Last Post: 02-08-2012, 01:37 PM
  4. Poulan Pro won't start
    By mig1980 in forum Small Engine & Mower Repair
    Last Post: 11-29-2010, 07:08 PM
  5. poulan pro PPb330
    By whitelee28 in forum Small Engine & Mower Repair
    Last Post: 10-21-2010, 04:13 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
