Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    Join Date
    Mar 2012
    Posts
    11
    Location
    Kentucky
    Mower
    Exmark
    How often do you clean the deck
    How often do you clean under and above the mower deck? And why do you clean it?
  2.
  3. #2
    Join Date
    Apr 2012
    Posts
    Location
    North Carolina
    Mower
    Toro
    Re: How often do you clean the deck
    I try to always blow the whole mower down with compressed air after every use, including under the deck. Packed grass cuttings trap moisture which breeds rust and pops paint.
  4. #3
    Join Date
    Mar 2012
    Posts
    11
    Location
    Kentucky
    Mower
    Exmark
    Quote Originally Posted by GaryLee View Post
    ah ok. So, besides rust, the grass underneath the deck does not effect the performance in any way? Like it doesn't keep the grass from circulating through the mower?
  5. #4
    Carscw's Avatar
    Join Date
    Aug 2011
    Posts
    6,339
    Location
    Georgia
    Mower
    Toro
    I do not clean the under side of the deck in over 40 years I have never had a deck rust out. I do blow the top of the deck off after every yard. If your getting so much grass stuck under the deck that it change how it cuts then just get a mower that is better for your needs
    Sent from my iPhone using LMF
  6. #5
    jimrs's Avatar
    Join Date
    Jun 2011
    Posts
    113
    Location
    Elm Grove, La
    Mower
    In the summer months I have never had that much of a problem except on top the deck. In the spring I have yet to see it dry enough to not stick to the underside of the deck. On the new Toro I have found lots of grass trapped and stuck to the deck as I mulch and the grass is full of water, I guess. I use the water hose attachment built on the deck and wash it out. I need to check my old JD and Honda to see if they also have an accumulation of stuck grass and get them cleaned up before they rust out. Forgot the original question I clean it after each use NOW.
  7. #6
    Join Date
    Mar 2012
    Posts
    5
    Location
    Georgia
    Mower
    Looking to Buy :)
    Just stop out in the yard before you park and use your leaf blower to clean it off.....you can even knock the dust off the air filter if you have the newer semi-exposed type filter. I do not like to park a dirty mower......
  8. #7
    Carscw's Avatar
    Join Date
    Aug 2011
    Posts
    6,339
    Location
    Georgia
    Mower
    Toro
    I feel it's better not to clean it at all then to spray it down with a water hose then put it in the shed or storage building
  9. #8
    Join Date
    Mar 2012
    Posts
    5
    Location
    Texas
    Mower
    LawnBoy
    Quote Originally Posted by Carscw View Post
    Is it safe to spray cold water over and around a hot engine?
  10. #9
    5,000 Post Club
    lawn mower fanatic's Avatar
    Join Date
    Jun 2012
    Posts
    6,759
    Location
    Pennsylvania
    Mower
    Two Honda HRX217HYA's and an HRR216TDA
    I used to clean the underside of my HRR after every single mow. If the grass was even slightly wet it would make a high-pitched sound and you would look under it, and there would be like 5 pounds of wet grass stuck to the deck. Luckily, with my HRX, I never have to clean it, because the grass JUST DOESN'T STICK! Even when it is wet. I love it!!!
    2013 4x6 custom utility trailer
    Honda HRX217(3)HYA mower
    Honda HRX217(5)HYA mower
    Honda HRR216TDA mower
    Echo SRM-225 trimmer
    Echo GT-2100 trimmer
    Echo PB-770T backpack blower
    Echo PB-255LN handheld blower
    Echo PE-225 edger
    Craftsman 24" 179cc dual-stage snow blower
    Black and Decker 22" electric hedge trimmer
  11. #10
    5,000 Post Club
    Ric's Avatar
    Join Date
    May 2010
    Posts
    5,729
    Location
    Florida
    Mower
    Toro Grandstand 36", Toro Z-Master 2000 48" Toro TurfMaster 30"
    I generally clean my decks weekly, just use the mojack, lift and use a plastic scraper then the air hose.
    G &G Lawn Care
    I have the right "NOT" to be tolerant of others because they are different, weird, or tick me off.
    The more People I meet, The more I Love My Dogs
Similar Threads
  1. not a clean cut in the middle?
    By bubba827 in forum Grasshopper Forum
    Last Post: 04-03-2012, 08:49 PM
  2. can i clean engine with a standard engine degreaser?
    By lawnnoob in forum Cub Cadet Forum
    Last Post: 08-31-2011, 04:03 PM
  3. Using Alcohol To Clean Fuel System
    By carl22 in forum Small Engine & Mower Repair
    Last Post: 11-18-2010, 05:17 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
