Results 1 to 6 of 6
  1. #1
    Join Date
    Mar 2012
    Posts
    Location
    North Carolina
    Mower
    Troy-Bilt
    New Member question about bad cutting
    I've got a Troy-Bilt Tuff Cut 200 that's about 8 years old, and for the last two years, it's been cutting like the blade needs to be sharpened, but that's not the case. I've gotten new blades, sharpened the blades, but the cut still leaves a lot of blades uncut and bent.
    Now, I've finally gotten a lawn that is pretty thick, so this may have something to do with it, but is there a problem with the power of my mower, or is there a different issue? I've adjusted the cutting height but that doesn't work either.
    Do I need to re-invest in a new mower or what? I'm not opposed to doing so, but if there's something I can try with this Troy-Bilt, I'd rather do that.
  2.
  3. #2
    Join Date
    Apr 2011
    Posts
    483
    Location
    Massachusetts
    Mower
    Husqvarna, Cub Cadet, MF, Craftsman
    Re: New Member question about bad cutting
    I would also think that the rpm could be an issue. If not fast enough the blade may not be lifting the grass.
  4. #3
    Parkmower's Avatar
    Join Date
    Jun 2011
    Posts
    891
    Location
    New York
    Mower
    Cub cadet, Jacobsen, Husqvarna, toro
    Yeah I'd look at and lube the throttle cable. Or change air and fuel filters. And if that doesn't do it clean the carb.
    All this is simple tasks and cost less the $20. That's alot less than a few hundred for a new mower.
  5. #4
    Grass ala Mowed's Avatar
    Join Date
    May 2010
    Posts
    207
    Location
    Suffolk Virginia
    Mower
    Toro Super Recycler with Kohler engine
    Is the blade level? if the wheels are bent or misadjusted the blade won't cut as well as it should.
  6. #5
    Join Date
    Mar 2012
    Posts
    4
    Location
    Massachusetts
    Mower
    I Don't Own a Mower :(
    Not familiar with the machine in question but is the grass clipping exit passage(s) clean and not restricted - causing a drop in vacunm that would keep the grass from being positioned for a clean cut? Also, is the blade housing area caked with old grass, causing a drop in the machine's ability to pull the grass up for a good cut?
  7. #6
    Join Date
    Mar 2012
    Posts
    Location
    North Carolina
    Mower
    Troy-Bilt
    Thanks for the answers everyone.
    Parkmower - I did check the throttle cable and it seems to be a little loose. It's only one speed but it feels like the throttle could be opened up a little bit more, which may cause an increase in RPM. I just changed the air filter, so I don't think that is the issue, but I will take a look at the fuel filter, or just go ahead and change it.
    Grass ala Mowed - As for the blade level, I think it's ok, but one of the wheels was bent inward, so I straightened it out so it's straight now. As for levelness, I think it's ok.
    Mr Q - The grass exit passage is clear, but the blade housing area could use a small cleaning, but I've kept up with it pretty well. The problem of the vacuum may be true, because I feel like the bag never fills 100% when I feel like it should be full. I've heard not to use water to clean this area. What would my best option be?
Similar Threads
  1. new member here with a bagging question
    By 89fltioga in forum Mower & Equipment Operation
    Last Post: 01-28-2012, 07:49 AM
  2. Mower deck Mower not cutting right?
    By matthewf13 in forum Craftsman Forum
    Last Post: 09-04-2011, 02:55 PM
  3. new member, have a push mower question
    By stackz in forum Small Engine & Mower Repair
    Last Post: 04-29-2011, 08:43 AM
  4. double cutting
    By LandN in forum The Front Porch
    Last Post: 03-19-2011, 11:59 PM
  5. Cutting back
    By monica123 in forum Lawn Care & Landscaping
    Last Post: 09-13-2010, 10:24 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
