Results 1 to 8 of 8
  1. #1
    1,000 Post Club
    RobertBrown's Avatar
    Join Date
    Aug 2010
    Posts
    1,278
    Location
    Florida
    Mower
    Ford
    Fuel Line on a string trimmer
    I have often thought the string trimmer is the most frustrating an annoying tool in the shed. It sometimes seems to me that the person who invented this device was evil, sadistic and should be held accountable.
    If you don't agree with that you have to admit there is certainly room for improvement, unless you enjoy having a noisey 2 stroke engine puking toxic smoke just a few feet from your head while you pound the thing on the ground wondering why the string doesn't unwind This time. All the while the extreme vibration has your rist aching with fatigue and clench your teeth in pain.... but don't forget to keep your lips pursed less you're teeth will fill with dirt and grass.
    As bad as it is wacking weeds with this device, I still use one when I can't get the wife to do it
    Currently I'm having an issue with the fuel lines cracking do to our ethanol laced fuel. The fuel lines and purge system needs to sealed well to work or air will enter the system and gas may leak out.
    After looking everywhere, I am unable to locate to correct size (interior diameter) fuel line. It seems to me that this model has 2 different diameters, although very similiar, that enter and exit the carbuerator. Also this model ( Toro 230028557 made by homelite) has very small hose clamps that are also impossible to locate.
    As much as I hate this thing I'm confident that is made well and worth fixing. It's only a few years old and hasn't been used much ( I'd rather visit the proctologist). Does anyone know where I can find the correct fuel line and some of those little wire clamp that hold the lines in place?
    Thanks RB
  2.
  3. #2
    rmancini's Avatar
    Join Date
    May 2010
    Posts
    134
    Location
    Western Washington
    Mower
    JD LX277, JD 790 loader, Cub Cadet Z Force L48 & Cyclone Rake
    Re: Fuel Line on a string trimmer
    I just went through the happiness of replacing my fuel line on a vintage 1987 Weedeater (brand name).
    My local feed store had the hose. Lots of fun getting the filter out and back into the gas tank.
    Mine was just OLD - I don't think the Ethanol contributed to the failure.
    You're right about the vibration , sore back, smoke/fumes and don't forget the absolute joy of peeling a nice big chunk of slug off your cheek!
    Rich
  4. #3
    Join Date
    May 2010
    Posts
    5,447
    Location
    Kansas, Butler county, Just east of DooDah
    Mower
    CTL
    Quote Originally Posted by RobertBrown View Post
    Thanks RB
    Most places that sell chainsaws and trimmers will have metric fuel line also motorcycle dealers and shops have it.
    If your fuel line has any special molded seals along the line you will need original equipment replacement or you will have to build your own using O-rings and fuel line... KennyV
  5. #4
    1,000 Post Club
    Join Date
    Aug 2010
    Posts
    1,278
    Location
    Florida
    Mower
    Ford
    I recieved the parts in the mail yesterday and replaced the primer bulb to the carb thgis afternoon and was able to get to trimming again
    I was able to get the parts from Amazon, a stored called "motown" I have purchased from them before, unfortunetly this time the parts were backordered and took longer than it should have. the trimmer is a Toro made by Homelite. I guess homelite makes trimmers for a lot of other companies, even Ryobi.
    On this model those little clamps are essential to proper seal on the pressurized fuel circuit.
    if anybody has questions let me know.
    RB
  6. #5
    Join Date
    Jul 2010
    Posts
    55
    Location
    Nevada
    Mower
    MTD - Yard-Man
    I have a similar problem with my weed whacker, but I never suspected the fuel line. Thanks for jarring my brain cells. I need to clean everything out for the winter anyway.
  7. #6
    twocycletim's Avatar
    Join Date
    Sep 2010
    Posts
    19
    Location
    Alabama
    Mower
    Badboy John Deere Cub
    Try this guy, I have purchased carb kits from him and have been satisfied with quality and service!
    matthews small engine parts items - Get great deals on Category 1, Category 2 items on eBay Stores!
  8. #7
    Join Date
    Apr 2011
    Posts
    14
    Location
    Kentucky
    Mower
    whatever I can find
    I went to my local Lowes home improvement center and found a product in their mower parts section you might be able to use. It's from the Arnold aftermarket parts company, a package with two one foot pieces of fuel line. One is 1/8" OD with 1/16" ID, the other is 3/16" OD with 3/32" ID. I paid about four bucks. Don't know if they'll fit your Toro but it looks like it may fit some Sears or Weedeater models.
  9. #8
    1,000 Post Club
    twall's Avatar
    Join Date
    Feb 2011
    Posts
    1,628
    Location
    New York
    Mower
    Snapper SR1433
    Wow. The last post here (before the one before mine) was SEVEN MONTHS ago. I think the problem's been LONG solved!
    Thanks for the tip, though.
    Sent from my WX445 using LMF
Similar Threads
  1. Cub Cadet keeps conking out-fuel pump?
    By just_puttering in forum Small Engine & Mower Repair
    Last Post: 04-02-2015, 04:36 PM
  2. Got to buy a String Trimmer
    By Rip in forum Mower & Equipment Operation
    Last Post: 07-20-2011, 03:40 PM
  3. Fence Line Post Trimers
    By stuckinnj in forum Mower & Equipment Buying & Pricing
    Last Post: 07-28-2010, 10:06 PM
  4. cusnman frount line
    By portya mill in forum Mower & Equipment Operation
    Last Post: 05-14-2010, 08:00 AM
  5. carb for string trimmer
    By dwbitting in forum Small Engine & Mower Repair
    Last Post: 05-07-2010, 12:01 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
