Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    talley2191's Avatar
    Join Date
    Mar 2012
    Posts
    78
    Location
    Maryland
    Mower
    John Deere X300
    Input regarding oil Leak/Fuel Pump
    I have read several accounts of oil leaking from the fuel pump, but many posts stop and the post originator never mentions what the issue was. I am experiencing that problem with my John Deere LA125 with 145 hours. I do not smell oil in the fuel, and have not yet tested the compression. Does anyone have any insights from past experience? Perhaps a similar model with similar engine (Briggs and Stratton 21 HP)? I guess the leading causes are either clogged breather, or rings going bad? I hope the latter is a long shot given the engine has only 145 hours on it.
  2.
  3. #2
    talley2191's Avatar
    Join Date
    Mar 2012
    Posts
    78
    Location
    Maryland
    Mower
    John Deere X300
    Re: Input regarding oil Leak/Fuel Pump
    Now I read a bit more regarding a possible cause is a head gasket. Is there a way to tell by looking wether or not it's a head gasket issue? Man, how can you have these issue with only 145 hours???
  4. #3
    OzRanga's Avatar
    Join Date
    Mar 2012
    Posts
    28
    Location
    Australia
    Mower
    Multiple Brands
    There is no way of telling unless you have a leakdown tester tool... But regardless it is a relatively easy job to change the head gasket anyway. 145 hours is not uncommon to blow one.....
    I would suggest that the cylinder head is checked to ensure it is flat (fine grit sandpaper on a sheet of glass or mirror) and do the head bolts up a little more than spec on reassembly....this will prevent reoccurance
  5. #4
    talley2191's Avatar
    Join Date
    Mar 2012
    Posts
    78
    Location
    Maryland
    Mower
    John Deere X300
    Will do if the test indicates it for sure. Thank you. I will do a compression test in the AM before I go further. What is a good compression reading? And what would figure is the more common occurrence, head gasket leak or clogged breather reed?
  6. #5
    1,000 Post Club
    pugaltitude's Avatar
    Join Date
    Jan 2012
    Posts
    1,141
    Location
    Scotland
    Mower
    Lots
    Quote Originally Posted by talley2191 View Post
    Doing a compression test on Briggs is no good as they do not release figures for it.
    A leakdown test is used to check the sealing capabilities of compression related components (valves, gaskets, rings) using a set air pressure which goes through special test equipment from Briggs.
    I read alot about compression tests on small engines and always wonder why?
    Iv never had to do one in 8-9 years of working on small engines.
    The "best" engine you will ever own!
    Briggs & Stratton MST.
  7. #6
    Join Date
    Mar 2012
    Posts
    7,307
    Location
    Wisconsin
    Mower
    Toro
    It does sound like a bad head gasket. Compression test may or may not tell you for sure. Only an experienced tech will get it right more than 75% of the time. I do a lot of compression tests but they only tell me that the cylinder is leaking, not where. The compression for a Briggs engine cold should be about 110-125 psi, after four good pulls. A leak down tester will tell the tech where the leak is. Problem, compression tester =$25 leakage tester = $175. Great tool but not for the average Joe. I would pull the head and clean everything I can and install a new head gasket. Overall this is the cheapest and easiest thing to do. Good luck.. Just thought of this. Have you pulled the valve cover and checked to see if the breather is stuck. Clean it with carb cleaner and shake it. You should hear it rattle.
  8. #7
    talley2191's Avatar
    Join Date
    Mar 2012
    Posts
    78
    Location
    Maryland
    Mower
    John Deere X300
    Thank you. Looks like a $7.55 part if I'm looking at the correct part number. I'll be sure to post follow up after the compression test in the morning.
  9. #8
    talley2191's Avatar
    Join Date
    Mar 2012
    Posts
    78
    Location
    Maryland
    Mower
    John Deere X300
    So compression test was normal and other signs (appears to have exhaust coming back through dipstick)seem to indicate head gasket does in fact need to be replaced. Only 145 hours....very disappointed in Briggs and Stratton. I'll follow up once the work is done. Thank you
  10. #9
    Join Date
    Mar 2012
    Posts
    7,307
    Location
    Wisconsin
    Mower
    Toro
    Not that unusual to replace. Make sure that you check and clean the cooling fins. Overheating is a cause of head gasket failure. As long as you have the head off clean out the carbon.
  11. #10
    talley2191's Avatar
    Join Date
    Mar 2012
    Posts
    78
    Location
    Maryland
    Mower
    John Deere X300
    Final post on the issue. Head gasket and a new spark plug and the mower is again running perfect. No smoke or oil coming from the oil pump. Thanks for the help and perhaps this thread will help someone else.
Similar Threads
  1. Cub Cadet keeps conking out-fuel pump?
    By just_puttering in forum Small Engine & Mower Repair
    Last Post: 04-02-2015, 04:36 PM
  2. Replies: 16
    Last Post: 12-22-2011, 03:18 PM
  3. Fuel Priming for new Pump
    By GTSRider in forum Cub Cadet Forum
    Last Post: 05-25-2011, 06:06 PM
  4. LX 172 Fuel Pump?
    By Darrel in forum John Deere Forum
    Last Post: 04-27-2011, 06:04 PM
  5. Repairs Yard Man fuel pump problem
    By SandbarBob in forum Mower & Equipment Operation
    Last Post: 10-12-2010, 12:07 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
