Results 1 to 8 of 8
Thread: honda hrc216hXA
  1. #1
    Join Date
    Mar 2012
    Posts
    48
    Location
    Oregon
    Mower
    honda hrc216hXA
    Hi, my name is bob, I'm new to the forum. Have 2 acres in oregon. I bought a couple of used commercial mowers that I'm fixing up. Got new carbs for them, and 1 starts right up, runs good, blade engages no problem. But the self propel in not working. If you lift the rear wheels off the ground they will roll but not strong enough when the weight of mower is on it. Any ideas? like to do what I can on my own if/when i can. Any tips would be appreciated, thanks
  2.
  3. #2
    Join Date
    Dec 2011
    Posts
    18
    Location
    Oklahoma
    Mower
    Dixon
    Re: honda hrc216hXA
    A lot of the time the problem is a streched belt. Another possibility is a streched drive cable that is not allowing the drive to fully engage. I'd start with a new belt.
    Ken
  4. #3
    1,000 Post Club
    robert@honda's Avatar
    Join Date
    Nov 2011
    Posts
    1,790
    Location
    Georgia
    Mower
    Re: honda hrc216hXA
    Hi Bob:
    Can you reply with the serial number? (it's on the back upper edge of the mower deck). With that, I can confirm the exact model you have, and share some "no self-propel" troubleshooting for your exact mower.
    FYI, as I recall, the HRC/HXA model has a shaft-driven transmission, so no belts. Could just be the hydrostatic fluid level....but get me that serial number and we'll help out.
    Caveat: I work for Honda, but the preceding was my opinion alone.
  5. #4
    Join Date
    Mar 2012
    Posts
    48
    Location
    Oregon
    Mower
    Re: honda hrc216hXA
    thanks Ken and Robert, It is a shaft driven. The serial number is MZAN 6034353 HXA, I opened and cleaned out the drive shaft area and cleaned the dirt/crud out of there and saw the hydrostatic drive fluid resevoir. I unscrewed the dip stick and it looks like it could use some fluid, what fluid does it take? thanks again Bob.
  6. #5
    1,000 Post Club
    Join Date
    Nov 2011
    Posts
    1,790
    Location
    Georgia
    Mower
    Re: honda hrc216hXA
    Okay Bob, I have a few documents to share with you:
    Service Bulletin on how to measure correct ground speed
    How to adjust cable to change ground speed
    How to inspect HST fluid level & bleeding procedure
    What is your email address, and I will send them direct?
    If you do need to add HST fluid, only use Honda HST fluid---no other brand is certified for use with this model. You can locate an authorized dealer in you area by using this tool; just check off LAWNMOWERS and enter your ZIP code:
    Honda Power Equipment - Find a dealer
  7. #6
    Join Date
    Mar 2012
    Posts
    48
    Location
    Oregon
    Mower
    Re: honda hrc216hXA
    Again, thanks Robert, I would be thrilled to have any info you would send. My email is bbewley01@comcast.net, thanks bob
  8. #7
    Join Date
    Mar 2012
    Posts
    48
    Location
    Oregon
    Mower
    Re: honda hrc216hXA
    thanks again, picked up a quart of hydro static oil from my repair shop today, thought I put in my email address twice bbewley01@comcast.net
  9. #8
    Join Date
    Mar 2012
    Posts
    48
    Location
    Oregon
    Mower
    Re: honda hrc216hXA
    thanks Robert, picked up some hst oil today, have tried to post my email but when I do it won't take my post. will try to look in control panel or private message you, bob
Similar Threads
  1. Replies: 5
    Last Post: 10-08-2012, 08:53 PM
  2. Buying Advice Which Honda?
    By Flossie in forum Honda Forum
    Last Post: 10-08-2012, 08:46 PM
  3. Honda HRR216VKA ($399) or Honda HRX217HXA ($699)
    By siradambeck in forum Mower & Equipment Buying & Pricing
    Last Post: 10-08-2012, 08:44 PM
  4. No Spark on Honda HRC216HXA
    By qz5kbk in forum Honda Forum
    Last Post: 09-28-2011, 08:41 AM
  5. Honda Hr-21
    By rz918 in forum Honda Forum
    Last Post: 08-23-2011, 02:32 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
