Results 1 to 3 of 3
  1. #1
    Join Date
    Feb 2012
    Posts
    Location
    Mississippi
    Mower
    Ferris
    Ferris IS 500z Hydro tank leaking
    I have a 2006 model Ferris IS 500z zero turn mower and the hydraulic tank leaks getting oil on the battery and everything else underneath the hydro tank. The tank has thick gaskets at the hose connections but they do not seal off completely. Has anyone encountered this problem and what remedies do you suggest?
  2.
  3. #2
    reynoldston's Avatar
    Join Date
    May 2011
    Posts
    5,657
    Location
    Marion,NY
    Mower
    Ferris, John Deere, Wheel Horse, Toro,
    Re: Ferris IS 500z Hydro tank leaking
    The oil tank is differant on my Ferris being a welded unit and sealed and the battery on top of it. It sound to me like the tank will have to be removed and new gaskets installed unless there is something you can tighen.
  4. #3
    Join Date
    Dec 2012
    Posts
    Location
    Florida
    Mower
    ferris is500z
    If the tank is plastic, like mine, t he problem is in the fitting that goes into the tank. it is a pressed-in fitting (no threads). The vibrations of the mower along with the hydraulic oil lubricating the connection causes the leak. Bad design.
Similar Threads
  1. Fluid leaking underneath the seat and gas tank
    By RachelleT in forum John Deere Forum
    Last Post: 04-20-2012, 03:17 PM
  2. LEAKING GAS Tank
    By Tall_Bill in forum Murray Forum
    Last Post: 02-29-2012, 12:03 AM
  3. Repairs Lawn Boy with leaking gas tank
    By T-Wort in forum Lawn Boy Forum
    Last Post: 12-24-2011, 07:37 PM
  4. Leaking gas tank and engine swap
    By TomW in forum Lawn Boy Forum
    Last Post: 08-29-2011, 08:57 AM
  5. leaking gas tank
    By glenn in forum Small Engine & Mower Repair
    Last Post: 04-28-2011, 05:36 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
