Results 1 to 4 of 4
  1. #1
    Join Date
    Jan 2012
    Posts
    Location
    Canada
    Mower
    Dr Field Mower
    Old DR 8hp field mower
    Can anyone help me find a shaft for the cutting deck of my older DR mower. They are no longer made. There is still lots of life left in the beast. It's the one with the skinny big wheels, probably built between 1987 and 1999. Plan B is to try to straighten the one I bent. Plan C is to have one made. They may have been called Bachtold machines back in the day? Thanks
  2.
  3. #2
    reynoldston's Avatar
    Join Date
    May 2011
    Posts
    5,638
    Location
    Marion,NY
    Mower
    Ferris, John Deere, Wheel Horse, Toro,
    Re: Old DR 8hp field mower
    Kind of through me off course here with the second trend. But I see you are thinking of trying to straighten it. Good Luck
  4. #3
    Join Date
    Mar 2012
    Posts
    21
    Location
    Oregon
    Mower
    DR Bachtold
    Quote Originally Posted by Kiwicut View Post
    I repair mowers for a non-profit arboretum. They have two and will be facing future spindle shaft replacement. I priced one at a machinist and he gave me the following numbers:
    quantity of 1, $150 total
    quantity of 2, $200 total or $100 each
    quantity of 3, $240 or $80 each
    $40 each after that.
    The higher price reflects having to take measurements to make them.
    Jim
    Jim Marshall
  5. #4
    Join Date
    Jan 2012
    Posts
    Location
    Canada
    Mower
    Dr Field Mower
    Thanks Jim. I managed to straighten the shaft pretty well but I've yet to run it. And whether it will stay straight is another matter. Sometimes the metal is affected. Here's hoping. Those prices you got sound reasonable though (from an old machinist's point of view. Cutting those two left hand threads would take time). By the way, check the bearings on the shaft, especially the lower one which was chewed to pieces on mine. The grass gets wound around the blade area and rips up the bearing seal. The bearings are very cheap to buy. Around $5.00 each.
Similar Threads
  1. Looking for DR "Bachtold" Field & Brush Mower Drive Gearbox
    By Valiant in forum Small Engine & Mower Repair
    Last Post: 09-22-2015, 05:43 AM
  2. How long will a full size football field take to cut using a 42" 24hp zero turn ?
    By Cutterboy in forum Commercial & Residential Lawn Mowing
    Last Post: 01-16-2013, 12:50 PM
  3. 8hp Briggs updraft carb leaking fuel while trying to start.
    By mrfixit in forum Briggs & Stratton Forum
    Last Post: 10-27-2012, 09:36 AM
  4. Hustler 4600 Diesel Dead in the Field
    By saverill in forum Hustler Forum
    Last Post: 08-22-2011, 01:21 AM
  5. STALLING PROBLEM WITH 8HP BRIGGS & STRATTON ENGINE
    By RONALD LECH in forum Briggs & Stratton Forum
    Last Post: 06-21-2011, 01:58 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
