Results 1 to 4 of 4
  1. #1
    Join Date
    Jan 2012
    Posts
    Location
    Massachusetts
    Mower
    Only runs at full throttle
    I have an older Echo SRM-210 Weed Whacker that's started giving me trouble. The issues were manageable but I decided to pull it apart and clean everything... now it's worse. Essentially, it will only start if I am giving it full throttle. Then, the RPM's will get very low and I'll have no power unless I close and open the choke several times in quick succession.
    If I let go of the throttle even the tiniest bit, it dies instantly.
    Thoughts?
  2.
  3. #2
    Join Date
    May 2010
    Posts
    5,447
    Location
    Kansas, Butler county, Just east of DooDah
    Mower
    CTL
    Re: Only runs at full throttle
    WELCOME to LMF...
    You say it is an older one... is it old enough to have the high & low adjusting screws on the carb?? KennyV
  4. #3
    Join Date
    Jan 2012
    Posts
    Location
    Massachusetts
    Mower
    I don't have it in front of me right now, but I don't believe so. I think I bought it in '02 or so
  5. #4
    Parkmower's Avatar
    Join Date
    Jun 2011
    Posts
    891
    Location
    New York
    Mower
    Cub cadet, Jacobsen, Husqvarna, toro
    Maybe the rings are shot. I've seen this on a few blowers and after consulting with a few others that was the conclusion. These units had seen alot of use.
    And when did they stop putting the hi-low adjustments on them?
    All the string trimmers we have in service have them and they're not that old. Have three saws less than two years old that have them.
Similar Threads
  1. How long will a full size football field take to cut using a 42" 24hp zero turn ?
    By Cutterboy in forum Commercial & Residential Lawn Mowing
    Last Post: 01-16-2013, 12:50 PM
  2. kohler hits governor at full choke but will die at half choke
    By johnwayne377 in forum Kohler Engine Forum
    Last Post: 09-29-2011, 10:58 PM
  3. Adding Throttle...
    By jmurray01 in forum Build-it Yourself
    Last Post: 09-02-2011, 05:20 PM
  4. Throttle link HELP !
    By Manner11 in forum Small Engine & Mower Repair
    Last Post: 08-13-2011, 12:30 AM
  5. Fuel Filter not staying full while running lawn mower
    By Cincyelite22 in forum Small Engine & Mower Repair
    Last Post: 07-06-2011, 08:13 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
