Results 1 to 5 of 5
  1. #1
    1,000 Post Club
    BKBrown's Avatar
    Join Date
    May 2010
    Posts
    1,415
    Location
    Virginia
    Mower
    VENTRAC
    71 WheelHorse 800 Special
    Some of you may remember that I repowered an 800 Special for a neighbor. The problem is that somewhere back in time someone removed the parking brake assembly and I can't even find any pictures or drawings of what it should look like.
    Any suggestions how I can lock the Brake / Clutch lever down so it does not roll when stopped ?
    Thanks in advance !
  2.
  3. #2
    reynoldston's Avatar
    Join Date
    May 2011
    Posts
    5,647
    Location
    Marion,NY
    Mower
    Ferris, John Deere, Wheel Horse, Toro,
    Re: 71 WheelHorse 800 Special
    The pictures look a lot like my newer 1990 Wheel Horse. The brake is on the left side and the brake band by the left rear wheel. The parking brake lever is a small lever by the shift lever. But don't know if yours would be the same or not? If you think so I will get into more for you.
  4. #3
    1,000 Post Club
    BKBrown's Avatar
    Join Date
    May 2010
    Posts
    1,415
    Location
    Virginia
    Mower
    VENTRAC
    Thanks reynoldston,
    I found some diagrams on a WheelHorse forum, but I will need to actually have the drawings and the tractor together to see what should work where.
    The brake band is on the left (facing the front) and the clutch/brake lever is pushed by the left foot - I would guess it is something that holds that brake lever down so the brake band is still engaged and drive belt is not engaged.
  5. #4
    1,000 Post Club
    BKBrown's Avatar
    Join Date
    May 2010
    Posts
    1,415
    Location
    Virginia
    Mower
    VENTRAC
  6. #5
    1,000 Post Club
    BKBrown's Avatar
    Join Date
    May 2010
    Posts
    1,415
    Location
    Virginia
    Mower
    VENTRAC
    stock 8 Hp Briggs from 800 Special
Similar Threads
  1. 266h wheelhorse help
    By inthetallgrass in forum Small Engine & Mower Repair
    Last Post: 12-07-2011, 07:08 PM
  2. 1971 Wheel Horse 800 Special
    By BKBrown in forum Toro/Wheelhorse Forum
    Last Post: 10-19-2011, 03:10 PM
  3. JD 316 with Kohler motor worth $800?
    By TerryD in forum Mower & Equipment Buying & Pricing
    Last Post: 09-14-2011, 12:55 AM
  4. LT155 for $800 about right?
    By Tom in forum Mower & Equipment Buying & Pricing
    Last Post: 08-22-2011, 11:52 AM
  5. Looking for a special lawnmower
    By badboy26 in forum Mower & Equipment Operation
    Last Post: 05-27-2011, 07:19 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
