Results 1 to 4 of 4
  1. #1
    Join Date
    Dec 2011
    Posts
    Location
    South Carolina
    Mower
    Troy-Bilt
    Cutting deck fails to engage
    I have a Troy Bilt super Bronco.
    The mowing deck is failing to engage to cutting mode. I have checked the belts, and they look fine.
    What are some possibilities for remedy? Thank you.
  2.
  3. #2
    reynoldston's Avatar
    Join Date
    May 2011
    Posts
    5,638
    Location
    Marion,NY
    Mower
    Ferris, John Deere, Wheel Horse, Toro,
    Re: Cutting deck fails to engage
    I don't know the mower but does it have a electric clutch. If so I would check the fuses.
  4. #3
    Join Date
    May 2010
    Posts
    5,447
    Location
    Kansas, Butler county, Just east of DooDah
    Mower
    CTL
    If it has an electric clutch... You should hear it click (Loud)... With the engine off...
    If you don't hear it... check fuses as mentioned, also check PTO switch, clutch and the key switch itself.... somewhere you are loosing 12 volts... KennyV
  5. #4
    SONOFADOCKER's Avatar
    Join Date
    Jun 2011
    Posts
    400
    Location
    New Jersey
    Mower
    TORO,JACOBSEN,CRAFTSMAN
    Forgot to mention checking the seat and brake safety . If one has failed blades will not engage - machine thinks your getting off with cutting blades in motion
Similar Threads
  1. Blades won't engage
    By AndrewJackson80 in forum Scag Forum
    Last Post: 11-14-2011, 10:57 AM
  2. Mower deck Mower deck not cutting grass on John Deere hydro 185
    By caryannw in forum John Deere Forum
    Last Post: 10-23-2011, 11:32 AM
  3. Attachments Swapping my cutting deck
    By kermit911 in forum Craftsman Forum
    Last Post: 08-07-2011, 11:52 AM
  4. Briggs & Stratton Coil fails when hot
    By originalswampfox in forum Briggs & Stratton Forum
    Last Post: 07-15-2011, 04:01 PM
  5. Repairs Clutch won't engage
    By bhalm1 in forum Snapper Forum
    Last Post: 11-25-2010, 01:25 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
