Results 1 to 9 of 9
Thread: leaking gas
  1. #1
    Join Date
    Aug 2010
    Posts
    4
    Location
    Florida
    Mower
    murray
    leaking gas
    I have a riding mower and when I put gas in it, It leaks all out of the air filter. what is wrong and what can I do to fix it????
  2.
  3. #2
    Join Date
    May 2010
    Posts
    8
    Location
    Brighton Mi
    Mower
    445
    Re: leaking gas
    Sounds like the needle is stuck open in the fload bowel of the carburator. You will have to remove the fuel bowel on the carb. and check the needle to see if it is stuck open. If you are not familuar with the carb then I would let a qualified tech look at it.
  4. #3
    Join Date
    Aug 2010
    Posts
    4
    Location
    Florida
    Mower
    murray
    Re: leaking gas
    if the needle is stuck how do i fit it???
  5. #4
    Join Date
    Jul 2010
    Posts
    25
    Location
    Illinois
    Mower
    Dixon
    Re: leaking gas
    Quote Originally Posted by cj9113 View Post
    Probably getting small speck of dirt under needle holding it from closing. I would remove bowl, clean, clean needle and examine IF it has noticeable worn area, replace it $4 or less, use Q-tip in needle seat and most importantly, buy an inline gas shut off valve and use it whenever the engine is not running.
    Walt Conner
  6. #5
    Join Date
    Jun 2010
    Posts
    60
    Location
    New York
    Mower
    I Don't Own a Mower :(
    Re: leaking gas
    Oh no... those are great tips to get the needle unstuck. I would start there. I would make sure to clean out the gas tank. If it still leaks you could have a hole somewhere on it. You might need to replace the gas tank.
  7. #6
    Join Date
    Aug 2010
    Posts
    25
    Location
    Indiana
    Mower
    Black and Decker
    Re: leaking gas
    Hopefully it is a quick fix! There is something I have never liked about having to replace a gas tank. Still it is better to be safe than it is sorry!
  8. #7
    Join Date
    May 2010
    Posts
    557
    Location
    Minnesota
    Mower
    country clipper (jazee)
    Re: leaking gas
    henry
    Also could be a pin hole in the float and it fills up with fuel and sinks so then it will not float and shut off the gas when the bowl is filled up. Just take it and raddle it and see if you hear any thing slushing back and fourth in it. If that does not work then dunk it in a small can of gas and see it gas so inside of the float.
  9. #8
    Michael's Avatar
    Join Date
    Aug 2010
    Posts
    35
    Location
    Eastern Canada
    Mower
    MTD - Yard Machines
    Re: leaking gas
    If you could be a little more informitive as to what have for an engine, I could be more helpful, it's like, "my red car stalled" well hello!!!! Please Please Please, to all, let us know what you are talking about, I have 230 trouble shooting manuals, but without a mod & ser # from the engine or unit I cannot help. I retired 3 years ago at 49, then realized I had nothing to retire to, so, I took the small engine repair course, I don't charge much, somtimes its the challenge, & somtimes its the interaction with customers, & then I come here to try & help, one more thing, don't grow old alone, take my word on that!!!!
    Michael
  10. #9
    twocycletim's Avatar
    Join Date
    Sep 2010
    Posts
    19
    Location
    Alabama
    Mower
    Badboy John Deere Cub
    Re: leaking gas
    I had this happen to me with a zama carb on a homelite trimmer, I cleaned the carb twice and it still puked gas from the carb intake, on examining the needle valve I found that there was material missing from the tip, replacing the valve solved thw problem.
Similar Threads
  1. Help me with my gas trimmer!
    By Bethieboo in forum Small Engine & Mower Repair
    Last Post: 08-17-2010, 10:23 AM
  2. Gas leak!
    By mowingmayhem in forum Small Engine & Mower Repair
    Last Post: 07-23-2010, 01:39 PM
  3. Cracked gas cap
    By mamaA in forum Small Engine & Mower Repair
    Last Post: 06-23-2010, 08:25 PM
  4. Sand in the Gas Tank
    By BlueGrass in forum Small Engine & Mower Repair
    Last Post: 05-30-2010, 06:50 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
