Results 1 to 8 of 8
Thread: Loss of power
  1. #1
    Join Date
    Jun 2011
    Posts
    35
    Location
    Maryland
    Mower
    Loss of power
    Hey everyone, I have a friend who mentioned that he has noticed a loss of power in his mower. What are some common problems that result in a loss of cutting power for a self propelled mower? If I have a pretty good idea of possible problems, then I could easily fix it. The mower is not that old, and has been maintained pretty well by this guy, but there is still a loss of power. Thanks for your help!
  2.
  3. #2
    Sammy the Red's Avatar
    Join Date
    Sep 2011
    Posts
    299
    Location
    Southern/Lower Michigan
    Mower
    Grasshopper-John Deere-IH Cub Cadet-Woods
    Re: Loss of power
    Make, model and age would help.
    http://www.lawnmowerforum.com/avatars/sammy-the-red.gif?type=sigpic&dateline=1319650460
  4. #3
    Join Date
    Jun 2011
    Posts
    35
    Location
    Maryland
    Mower
    I don't really know who makes it, this was just a comment from my friend, although the mower is on the cheeper side, and it's maybe 2-3 years old.
  5. #4
    Join Date
    Aug 2011
    Posts
    94
    Location
    welshpool
    Mower
    MTD - Yard-Man
    Re: Loss of power
    Los off power can be caused by a build up of carbon in the exhaust check that
  6. #5
    Join Date
    Jun 2011
    Posts
    35
    Location
    Maryland
    Mower
    Yea I was thinking it was maybe the spark arrestor screen, or muffler. Could it be anything else? Also what are some commonly overlooked tune up matinence?
  7. #6
    reynoldston's Avatar
    Join Date
    May 2011
    Posts
    5,645
    Location
    Marion,NY
    Mower
    Ferris, John Deere, Wheel Horse, Toro,
    Re: Loss of power
    Quote Originally Posted by Bacon8r View Post
    I would guess you might be talking about the spark plug and filters that would be a cheap start. My self would be thinking valve adjustment and then maybe carbon build up. I have found with a pluged muffler you get no high speed.
  8. #7
    Join Date
    Jun 2011
    Posts
    35
    Location
    Maryland
    Mower
    I'm not too familiar with the valve adjustment.... Can a guy do it or do you have to bring it to a mechanic?
  9. #8
    Join Date
    May 2011
    Posts
    5,645
    Location
    Marion,NY
    Mower
    Re: Loss of power
    Quote Originally Posted by Sammy the Red View Post
    Over head valves not a bad job, put piston TDC., Compression stroke, piston at top , remove valve cover, you will see a adjustment on rocker arms, .006 to .008 intake valve clearance between valve stem and rocket arm and .010 to .012 for exhaust. If you have a flat head it is a bit more work because you need to remove the head and valves and then grind the valve stems down to get your clearance. Best to know what you have like Sammy said. Before you get into that try the easyer and cheaper things frist, New spark plug and all new filters, gas and air, and oil change things your mower can use anyways. Start small and then go into bigger things.
Similar Threads
  1. John Deere 320 lawn tractor has loss of power
    By nate81 in forum Small Engine & Mower Repair
    Last Post: 08-20-2017, 05:11 PM
  2. Power Rakes
    By Manny in forum Lawn Care & Landscaping
    Last Post: 04-29-2014, 05:19 PM
  3. 25 Hp Kohler Gravely... black smoke under load.. loss of power??
    By gunner181 in forum Gravely/Ariens Forum
    Last Post: 06-10-2012, 04:53 PM
  4. steering loss
    By DonUp in forum Ventrac Forum
    Last Post: 11-19-2011, 11:07 AM
  5. Power up and down
    By stanley in forum Small Engine & Mower Repair
    Last Post: 03-26-2011, 04:39 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
