Results 1 to 8 of 8
  1. #1
    Join Date
    Sep 2011
    Posts
    5
    Location
    Indiana
    Mower
    MTD - Yard Machines
    Fire Coming from Exhaust
    Hello,
    This has happened twice now on my old Wal-mart Yard Machine... I completely mow my yard.. turn off and a small fire starts coming out of the exhaust pipe..
    At first I thought maybe old grass was in the cover or muffler , ( The cover with all the holes in it attached to a 3/4" or so, exhaust pipe)... It is all rusted out.. I looked again and the flame is definitely coming from the 3/4" pipe.. No Grass... So I'm guessing it is a build up of gas that can't burn because of the exhaust shooting out carbonioxide with little oxygen to fuel the flame.. Plus the air compression.. But that is just a guess..
    What can I do to repair this and keep these fires from happening..?
    Thanks Bill
  2.
  3. #2
    Join Date
    Aug 2011
    Posts
    79
    Location
    Connecticut
    Mower
    toomany
    Re: Fire Coming from Exhaust
    I had a similar problem with my 1986 craftsman lawn tractor. It backfired so much (there were flames comming out the muffler) that the muffler glowed red, then the muffler screws got melty and rattled out and the muffler just fell off. Now I just run the mower without the muffler because I don't feel like putting a new shear key in it (It has a timing problem).
    So if that sounds like what may be happening with your mower, then its a timing problem and you need a new shear key.
    -brandon
  4. #3
    Join Date
    Sep 2011
    Posts
    5
    Location
    Indiana
    Mower
    MTD - Yard Machines
    Yea, I don't notice it back-firing.. It has back-fired before, but it runs ok I think.. It just catches on Fire..Ha... Flames right out of the exhaust...
    Bill
  5. #4
    Sammy the Red's Avatar
    Join Date
    Sep 2011
    Posts
    299
    Location
    Southern/Lower Michigan
    Mower
    Grasshopper-John Deere-IH Cub Cadet-Woods
    Let it idle for a minute before you shut it down.
  6. #5
    Join Date
    Aug 2011
    Posts
    79
    Location
    Connecticut
    Mower
    toomany
    If it's an OHV engine check that your pushrods aren't bent at all, and make sure the valves are opening and closing correctly.
  7. #6
    SONOFADOCKER's Avatar
    Join Date
    Jun 2011
    Posts
    400
    Location
    New Jersey
    Mower
    TORO,JACOBSEN,CRAFTSMAN
    The carb has an anti back fire solenoid on it . Stops fuel when you shut off the machine . Yours is deliver fuel & fuel is igniting when the exhaust valve is open . Fuel ignites due to normal heat . Try throttle down before turning it off .
  8. #7
    wjjones's Avatar
    Join Date
    May 2011
    Posts
    1,456
    Location
    Tennessee
    Mower
    YS 4500, and DYS 4500, and Bunton 61" ztr
    Quote Originally Posted by SONOFADOCKER View Post
    Yep my manual says idle for 15 to 20 seconds before shutting off if i dont mine backfires loud..
  9. #8
    rmancini's Avatar
    Join Date
    May 2010
    Posts
    134
    Location
    Western Washington
    Mower
    JD LX277, JD 790 loader, Cub Cadet Z Force L48 & Cyclone Rake
    I've noticed that as the Ethanol content in gasoline increased, a lot of my equipment started to run "funny" and some backfired and dieseled. I tried the middle grade of gas (instead of regular) and I haven't had any problems since. I'm thinking that carbon deposits on older equipment may heat-up and glow causing the cylinder(s) to fire when the exhaust valve is open. The higher Octane gas seems to prevent this.
    It's for sure a little more expensive to use better gas, but, but I'd rather not take the chance of damaging my goodies.
    Rich
Similar Threads
  1. Repairs briggs 14hp. twin backgfires thru exhaust
    By pggarden in forum Mower & Equipment Operation
    Last Post: 09-01-2015, 07:31 PM
  2. Engine Exhaust blowing white smoke and oil.
    By Jeffvador in forum Troy-Bilt Forum
    Last Post: 12-18-2011, 07:05 PM
  3. Modified Snapper Exhaust
    By calrec1 in forum Snapper Forum
    Last Post: 09-19-2011, 01:50 PM
  4. briggs 14 hp. twin backfires thru exhaust
    By pggarden in forum Small Engine & Mower Repair
    Last Post: 10-08-2010, 12:24 PM
  5. Blade keeps coming off
    By stanley in forum Small Engine & Mower Repair
    Last Post: 09-30-2010, 10:16 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
