Results 1 to 2 of 2
  1. #1
    Join Date
    Sep 2011
    Posts
    Location
    Texas
    Mower
    JD Z445 Stalling
    Hello, I have a JD Z445 mower with the Kawasaki engine and 48" cutter deck. I bought it in 2008 and so far has been a great mower to mow the 1.5 acres I have. Out of nowhere it began to stall as if a belt was putting a drag on the engine. I made sure all the belts were clear of obstructions and greased the cutter blade bearings and it will work for a few minutes and then starts doing the same thing again. As long as the deck is not engaged it runs fine so I figure it may be in the electric clutch so something like that. Anybody run into this type of thing before?
  2.
  3. #2
    SONOFADOCKER's Avatar
    Join Date
    Jun 2011
    Posts
    400
    Location
    New Jersey
    Mower
    TORO,JACOBSEN,CRAFTSMAN
    When the electric PTO fails it's 50% chance it just doesn't turn on & the other is when it seizes you think you seized the motor because even the starter won't turn the motor ...
Similar Threads
  1. JD Z425 vs Z445
    By caliber1 in forum Mower & Equipment Buying & Pricing
    Last Post: 04-05-2018, 12:45 PM
  2. EZTrak Z445 idle problems
    By slingblade in forum John Deere Forum
    Last Post: 03-27-2017, 10:43 PM
  3. John Deere Z445 Mulch Kit Problems
    By bos in forum John Deere Forum
    Last Post: 05-26-2013, 09:59 AM
  4. EZ Trak Z445
    By buckhunter in forum John Deere Forum
    Last Post: 09-13-2011, 08:37 PM
  5. john deere z445
    By slingblade in forum Small Engine & Mower Repair
    Last Post: 09-08-2011, 07:15 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
