Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    Aug 2011
    Posts
    79
    Location
    Connecticut
    Mower
    toomany
    Make mower go faster, smaller pulley
    If I were to put a smaller pulley on the rear of my old craftsman 5 speed maual to make it go faster, how fast could I get it to go. And how small of I pulley could I get away with without loosing so much torque that I wouldn't be able to get a a big hill? The engine is a 1985 B&S 11HP flathead.
  2.
  3. #2
    Join Date
    May 2011
    Posts
    549
    Location
    Indiana
    Mower
    725 Grasshopper JD 430 diesel JD 180 JD Z445
    Re: Make mower go faster, smaller pulley
    Quote Originally Posted by crazyoldtractor View Post
    Why do you want to go so fast are you going to race it.
    " THERE ARE TWO KINDS OF PEOPLE THAT OWN TRACTORS "
    THOSE THAT OWN A JOHN DEERE AND THOSE THAT WISH THEY DID
  4. #3
    Join Date
    Aug 2011
    Posts
    79
    Location
    Connecticut
    Mower
    toomany
    No, not gonna race it. Its just fun to ride it around on my trails but doesn't go that fast. Its my beat up tractor I use for utility, towing stuff around, pulling, and fun.
  5. #4
    Join Date
    May 2010
    Posts
    5,447
    Location
    Kansas, Butler county, Just east of DooDah
    Mower
    CTL
    It will be twice as fast if you half the circumference.... BUT it will have a bit less than half the torque.
    You will also have a problem with belt slipping on a smaller pulley...
    So you will have to determine how much torque you want to be left with... KennyV
  6. #5
    1,000 Post Club
    jmurray01's Avatar
    Join Date
    Apr 2011
    Posts
    1,490
    Location
    Scotland
    Mower
    Sterling Cyclone with Tecumseh Vantage 35
    Quote Originally Posted by KennyV View Post
    Yep, I was just going to say, you'll loose torque, which on a mower, is low at the best of times.
    I'd reduce the pulley circumference by 1/4 if I were you.
    You will increase the speed a little bit, but still retain a reasonable amount of torque.
    Live every day as if it's your last - because one day - it will be.
  7. #6
    Join Date
    May 2011
    Posts
    549
    Location
    Indiana
    Mower
    If you have room I would put larger pulley on the engine rather than smaller one on the transaxle because you will gain pulley surface and that means NO belt slip.
    Then you can start shopping for a bigger engine to put on it.
  8. #7
    1,000 Post Club
    jmurray01's Avatar
    Join Date
    Apr 2011
    Posts
    1,490
    Location
    Scotland
    Mower
    Quote Originally Posted by Black Bart View Post
    Ah, of course, I didn't think of that!
  9. #8
    Duramax's Avatar
    Join Date
    Nov 2011
    Posts
    9
    Location
    Florida
    Mower
    murray
    will a regular drive belt stretch withought breaking if you do that?
    murray 17 hp BS wide body hydro auto STOCK
    trying to make fast help please
  10. #9
    Dangeroustoys56's Avatar
    Join Date
    Sep 2011
    Posts
    117
    Location
    Florida
    Mower
    Multiple brands
    This isnt a hydro is it? Hydros cant be modifed or theyll self destruct. Its not a matter of making it faster, youll need to do more then that- like brakes, steering, ect.
    My first couple of mod tractors were failures, not in the speed aspect, but saftey - barreling around and no brakes = trip to the ER .
    One the transmission broke on me - luckily as i was just taking off, if it happened while at speed, id be lucky not to be paralyzed.
    The second was way too fast for a 90% stock tractor - after more then a couple near bad crashes, i took it apart- was too dangerous to drive it.
    My current mods in progress will have good brakes, lowering, ect - built to handle faster speeds, not just thrown together like my previous machines.
  11. #10
    Duramax's Avatar
    Join Date
    Nov 2011
    Posts
    9
    Location
    Florida
    Mower
    murray
    Quote Originally Posted by Dangeroustoys56 View Post
    whats wrong with hydro's and why?
    mine is a hydro
Similar Threads
  1. Walk behind Mow Faster
    By lizard in forum Mower & Equipment Operation
    Last Post: 11-27-2012, 01:46 AM
  2. Husqvarna Model# 580 rs Self propelled Mower Idler pulley bracket mounting
    By rocko720 in forum Small Engine & Mower Repair
    Last Post: 05-06-2011, 11:10 PM
  3. Faster mower
    By Penalty333 in forum Craftsman Forum
    Last Post: 03-08-2011, 06:13 PM
  4. Have to make a confession
    By JDgreen in forum The Front Porch
    Last Post: 02-16-2011, 08:40 AM
  5. Smaller saws
    By Roger in forum Mower & Equipment Operation
    Last Post: 08-21-2010, 09:20 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
