Results 1 to 7 of 7
  1. #1
    Join Date
    Aug 2011
    Posts
    79
    Location
    Connecticut
    Mower
    toomany
    mower only runs with choke on
    I have an old lawn tractor that I just got. I think its a 1986 model. I got it all cleaned up, including the carb and air filter. Maybe I didn;t clean the carb well enough. The tractor will only run with the choke on and it backfires A LOT. When I turn the choke off the mower goes off. I think the backfiring problem is a timing problem. Anyone know whats wrong.
    Mower info: Craftsman 917 255736
    Engine info: craftsman B&S model: 252707, type: 0621-03, code: 36040111
  2.
  3. #2
    Join Date
    Sep 2011
    Posts
    Location
    Minnesota
    Mower
    Re: mower only runs with choke on
    Quote Originally Posted by crazyoldtractor View Post
    I just had this problem with my old mower and it was indeed the carb. If your flow of fuel to the carb is good I would go there again.
  4. #3
    rekees's Avatar
    Join Date
    May 2010
    Posts
    191
    Location
    Indiana
    Mower
    You might try adding some Seafoam to the gas and perhaps it will clean the carb.
  5. #4
    1,000 Post Club
    jmurray01's Avatar
    Join Date
    Apr 2011
    Posts
    1,490
    Location
    Scotland
    Mower
    Sterling Cyclone with Tecumseh Vantage 35
    Sounds like it is running too lean, as when the choke is advanced, it lets less air in, and thus needs less fuel.
    I think you should give your carburettor another clean and check the float is working properly.
    Also maybe try changing the spark plug.
    Live every day as if it's your last - because one day - it will be.
  6. #5
    1,000 Post Club
    reddragon's Avatar
    Join Date
    Jun 2011
    Posts
    1,377
    Location
    southern oregon
    Mower
    little this...little that
    this is common....its fuel starvation.....you will need to completely go thru the carb....something is blocking the fuel..could be a bleed hole stopping pressure equilization too...take it apart and take pictures for us....ive just broke my own record and rebuilt 17 carbs this last week...so im in the carb mood......i know this carb well...its a 491 series...this one is great in the fact you can completely remove the emulsion tube assy.....the main jet has a needle at the bottom of the bowl and you can back it out and see if that helps right there.....thers also an idle screw...you want to get it to run good at high speed with the main jet and idle low with the idle screw on the side...is there any corrosion?..... http://outdoorpowerinfo.com/repairs/...o-jet_carb.asp
    '97 MURRAY 15.5hp TECUMSEH..42"...6SP............'04 TROY-BILT BRONCO....18.5 BRIGGS..42"...AUTO...CRUISE...
    '06 MTD YARD MACH...15.5 HP B&S...42"..6 SP ....'99 CRAFTSMAN...19.5 HP....42"...6SP
    '94 AYP KGRO...16HP B&S...42".....5SP ................'77 SEARS 18-6...18HP ONAN ...42"....6SP
    '98 CRAFTSMAN..17HP B&S ..42"...HYDRO............'93 MTD YARD MAN 18HP B&S ...42"....HYDRO
    '02 CRAFTSMAN LT1000.. 17HP B&S...42"..5SP.....'00 MTD 679..17.5 TECUMSEH...42"....7Sp
  7. #6
    Join Date
    Aug 2011
    Posts
    79
    Location
    Connecticut
    Mower
    toomany
    I fixed the choke problem with the screw on the bottom of the bowl. But the thing still backfires a lot when its running. I think its the timing, like the shear key or something, but I don't know how to see if that is the problem.
  8. #7
    1,000 Post Club
    reddragon's Avatar
    Join Date
    Jun 2011
    Posts
    1,377
    Location
    southern oregon
    Mower
    youll need to pull the top shroud off to expose the flywheel....... Parts and Diagrams for Briggs and Stratton 252707-0621-03
Similar Threads
  1. Craftsman Mower Problem: Runs fine until blades are engaged.
    By Shadetree_Dechanic in forum Small Engine & Mower Repair
    Last Post: 06-17-2015, 10:16 AM
  2. Briggs And Stratton Snapper riding lawn mower runs but dies after 5 sec
    By dssdj2009 in forum Briggs & Stratton Forum
    Last Post: 08-29-2011, 04:04 AM
  3. JD 737 will not run unless the choke is on
    By kpaquet in forum John Deere Forum
    Last Post: 07-02-2011, 08:37 AM
  4. Only Runs With Choke On
    By graycenphil in forum Small Engine & Mower Repair
    Last Post: 06-29-2011, 07:31 PM
  5. Honda mower runs rough
    By small Engine Repair in forum Site Discussion
    Last Post: 05-27-2011, 06:50 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
