Results 1 to 6 of 6
  1. #1
    Join Date
    Sep 2011
    Posts
    Location
    Buffalo
    Mower
    model 2146 Onan Engine 14 HP
    Smile Cub Cadet - Backfire problem
    Cub Cadet - Backfire problem.
    I have a cub Cadet model 2146 with a 14 HP Onan engine model ZX390 11317D. The engine runs fine except it backfires eight out of ten times when the key is turned off. This happens regardless of throttle RPM speed. There is also a 10 second spark knock prior to the backfire. What may be the problem or a solution?
    Thanks to all.
  2.
  3. #2
    Join Date
    May 2010
    Posts
    151
    Location
    Monmouth
    Mower
    Re: Cub Cadet - Backfire problem
    let it idle and cool down before turning off the key
    JMAC Small Engine Repair, Monmouth Illinois
  4. #3
    Join Date
    Mar 2011
    Posts
    881
    Location
    Washington
    Mower
    honda 1031, cub cadet 2164, jacobsen park 30, simplicity
    Is your carb equipped with an anti-backfire fuel solenoid? If so, it may have given up the ghost in the open position (unusual, but possible).
  5. #4
    Join Date
    Aug 2011
    Posts
    88
    Location
    Hampshire UK
    Mower
    Husqvarna
    When was the top end last de-cocked?
  6. #5
    Join Date
    Sep 2011
    Posts
    Location
    Buffalo
    Mower
    Sorry, but I don't know what this means. Are you talking about timing?
    "When was the top end last de-cocked?"
    Thank you for the prompt response.
  7. #6
    Join Date
    Mar 2011
    Posts
    881
    Location
    Washington
    Mower
    Post Re: Cub Cadet - Backfire problem
    Quote Originally Posted by trickydickie View Post
    I'll guess he meant "de-coked", as in carbon removal. You might try a slug of Seafoam in there. Stand off to the side when you fire it back up!
Similar Threads
  1. Cub cadet 128 Problem
    By pizzaman in forum Cub Cadet Forum
    Last Post: 04-14-2012, 02:28 PM
  2. Cub Cadet 2186 PTO Problem
    By Rooster7 in forum Small Engine & Mower Repair
    Last Post: 07-29-2011, 12:47 PM
  3. New member with a Cub Cadet Problem, hello Everyone!
    By floridabowler in forum Cub Cadet Forum
    Last Post: 07-27-2011, 05:08 PM
  4. Cub Cadet 4816F Hydro Trans Problem
    By chjr69 in forum Small Engine & Mower Repair
    Last Post: 05-27-2010, 10:12 PM
  5. cub cadet backfire
    By whitey1957 in forum Small Engine & Mower Repair
    Last Post: 05-10-2010, 08:51 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
