Results 1 to 5 of 5
  1. #1
    Join Date
    Sep 2011
    Posts
    Location
    Maryland
    Mower
    MTD - Yard-Man
    Honda GCV160 Carburetor Question
    OK. Rookie mistake made. I inherited a MTD rotary push mower with a Honda GCV160 engine, and yesterday it wasn稚 running right, so I thought I壇 give the air cleaner and carb a little cleaning. Took the air cleaner off, and saw a plastic base which I thought was just a cover for the carburetor. There were three bolts holding it on, so I went about removing them, and?.the whole carburetor came off the engine, with gaskets and spacers and a metal plate sliding off and scattering everywhere!! I started trying to guess where they all went, but of course that was useless. It was also very awkward trying to hold everything together while trying to get it back on the engine, SIDEWAYS, with all the linkages intact, and then get the bolts back in. Obviously, I did something out of sequence because I don稚 think it痴 supposed to happen that way. Can anybody provide me with detailed step-by-step instructions for removal and replacement of the carburetor on this engine? Or refer me to somewhere I can find them? Thanks very much.
  2.
  3. #2
    Join Date
    Aug 2011
    Posts
    88
    Location
    Hampshire UK
    Mower
    Husqvarna
    Re: Honda GCV160 Carburetor Question
  4. #3
    1,000 Post Club
    jmurray01's Avatar
    Join Date
    Apr 2011
    Posts
    1,490
    Location
    Scotland
    Mower
    Sterling Cyclone with Tecumseh Vantage 35
    Did you get it fixed ?
    Live every day as if it's your last - because one day - it will be.
  5. #4
    Join Date
    Sep 2011
    Posts
    Location
    Washington
    Mower
    MTD
    I had that problem with reassemble after everything fell off as I disassembled it. I found an illustration from this place that shows everything inclucing parts. You may have to join their
    freebee website but only took a few minutes : I used Model GJAEA and it took me to the area.
    Here is the website:
    eReplacementParts.com
    and here is where I found the illustration:
    Model Number Search : eReplacementParts.com
    good luck as you need extra hands to do this one!
  6. #5
    Join Date
    Aug 2013
    Posts
    23
    Location
    Finland
    Mower
    I had the similar problem with my GCV190. My gaskets and spacers looked like this (in order):
    https://www.dropbox.com/s/wxd2xbfs5hyzxnn/IMG_0454.JPG
    The three left ones go between the carburettor and the air filter, and the two rightmost between the carburettor and the cylinder.
    (One gasket was still attached to the cylinder.)
    I put the link here, because in my machine the spacers and gaskets and their order was different from any picture I found in the net.
    The little hole (it's alignment) revealed...
Similar Threads
  1. Repairs Model 10313 Carburetor question
    By rover_nut in forum Lawn Boy Forum
    Last Post: 04-13-2012, 07:33 AM
  2. Honda GCV160 Carburetor Problem
    By jhcoleman1953 in forum Small Engine & Mower Repair
    Last Post: 01-16-2012, 04:43 PM
  3. Honda HRR216 question
    By MIG in forum Honda Forum
    Last Post: 06-27-2011, 03:42 PM
  4. Craftsman with 5.5 hp Honda and BBC - Piston lock question
    By nick in forum Small Engine & Mower Repair
    Last Post: 06-03-2011, 04:57 AM
  5. carburetor question
    By bluebell2 in forum Mower & Equipment Operation
    Last Post: 03-20-2011, 11:02 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
