Results 1 to 7 of 7
  1. #1
    Join Date
    Sep 2011
    Posts
    5
    Location
    Pennsylvania
    Mower
    john deere and a walk craftsman
    snow blowers electric start wont work
    we have a craftsman snow blower and the electric start wont work, it just whines.. The snow blower will work if I pull the cord.. So I know it is the electric start and not the snow blower. Any suggestions on how to fix this problem. Your help would be appreciated
  2.
  3. #2
    Join Date
    Aug 2011
    Posts
    88
    Location
    Hampshire UK
    Mower
    Husqvarna
    Re: snow blowers electric start wont work
    It could be the battery is a bit flat and does not have enough power to engage the starter motor or the bendix on top of the starter motor is stuck down and not engaging with the flywheel when you turn the key.
  4. #3
    Join Date
    Sep 2011
    Posts
    5
    Location
    Pennsylvania
    Mower
    so how do I fix this?
  5. #4
    1,000 Post Club
    jmurray01's Avatar
    Join Date
    Apr 2011
    Posts
    1,490
    Location
    Scotland
    Mower
    Sterling Cyclone with Tecumseh Vantage 35
    As I said on your other thread, you will need to change your battery. Or at least I would.
    Edit - Sorry, I don't think you did post another thread, I was thinking of a similar one. My memory seems to be having another off day. Been having a lot of those recently
    Live every day as if it's your last - because one day - it will be.
  6. #5
    Join Date
    Sep 2011
    Posts
    5
    Location
    Pennsylvania
    Mower
    not a problem, appreciate the help... The battery is fine I assume as the snowblower works when i use the pull rope.. but i will check it out anyway.. If the battery is fine then what is my next step? thanks
  7. #6
    Join Date
    Aug 2011
    Posts
    88
    Location
    Hampshire UK
    Mower
    Husqvarna
    Hi
    Start by charging the battery it never hurts to start with plenty of power.
    I would go for the bendix sticking first. If you can see it without removing to engine covers then spray it with a little WD40 or some aerosol based releasing oil give it time to soak in then try starting.
    If this does not work then you will need to remove the engine covers to give you access to the starter motor when you have done this clean the top of the starter motor and rotate it by hand to make sure the bendix goes up and down give it a little spray of WD40. At this point I would pull off the plug cap so the engine will spin over but not start to test the starter motor is working ok by turning the ignition key.
    If it works great put it all back together.
    If not you will need to take the starter motor off and test it off the machine you can use a jump lead from the negative side of the battery to earth the starter and one from the positive battery terminal to the wire connection on the starter motor. I normally do this with the starter motor on the ground and with one foot on it to keep it still and just very quickly touch the positive lead on the starter motor terminal. Be careful it will jump around but you only need to try it once.
    Chances are you will not need to remove the starter motor.
    Let me know how you get on.
  8. #7
    1,000 Post Club
    jmurray01's Avatar
    Join Date
    Apr 2011
    Posts
    1,490
    Location
    Scotland
    Mower
    Quote Originally Posted by Paul C View Post
    No, you are wrong there I'm afraid. Because it works with the pull cord, that doesn't mean the battery is fine. Pulling the cord to start doesn't use any battery power, as you are physically turning the engine by hand, and doing what the starter motor would do.
Similar Threads
  1. mower wont start
    By ffsmith in forum Small Engine & Mower Repair
    Last Post: 02-17-2012, 09:19 AM
  2. mower wont start
    By sean in forum Small Engine & Mower Repair
    Last Post: 02-04-2012, 11:22 AM
  3. JD L140 wont start
    By JustinTractor in forum John Deere Forum
    Last Post: 06-27-2011, 03:45 PM
  4. rer wont start
    By jeremy in forum Small Engine & Mower Repair
    Last Post: 06-11-2011, 12:31 PM
  5. wont start
    By bill reid in forum Toro/Wheelhorse Forum
    Last Post: 05-26-2011, 02:25 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
