Jepritchett
- Aug 18, 2011
- Threads
- 1
- 3
My RZT50 is cutting uneven, it is cutting lower on the left side. We have check the deck and blades and they are both higher on the left side by about 1/2 inch, but that same side is cutting lower. We measured the blades, from the side, and the left is higher. Measured them from the front and back and both measurements are higher on the left. So why is it cutting lower on that side? And how do we fix it? It really makes the yard and field look horrible.
