Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Join Date
    Aug 2011
    Posts
    Location
    Virginia
    Mower
    RZT50 uneven cutting problem
    My RZT50 is cutting uneven, it is cutting lower on the left side. We have check the deck and blades and they are both higher on the left side by about 1/2 inch, but that same side is cutting lower. We measured the blades, from the side, and the left is higher. Measured them from the front and back and both measurements are higher on the left. So why is it cutting lower on that side? And how do we fix it? It really makes the yard and field look horrible.
  2.
  3. #2
    Join Date
    May 2011
    Posts
    549
    Location
    Indiana
    Mower
    725 Grasshopper JD 430 diesel JD 180 JD Z445
    Re: RZT50 uneven cutting problem
    Quote Originally Posted by Jepritchett View Post
    Did you rotate the blade and check the height of both ends, The blade may be bent.
  4. #3
    Join Date
    Aug 2011
    Posts
    Location
    Virginia
    Mower
    Yes, measured the blades facing front to back and the left was hire than the right on the front and the back. Also measured with the blade facing the side and the left was hire.
  5. #4
    LT1045wrh's Avatar
    Join Date
    Jul 2011
    Posts
    43
    Location
    Weirsdale, FL
    Mower
    CC_Ariens_Murray_JD_Craftsman
    Sounds like a bent blade. I had this happen once and scalped one side of the cut-path. Also, you may want to check that your tire pressure is correct for all tires.
    Good luck and mow on,
    Wendy
  6. #5
    Join Date
    Aug 2011
    Posts
    Location
    Virginia
    Mower
    We thought it could be a bent blade. But if you have both right and left blades facing front to back, and measure both blades at the front, the left is higher. If you measure from the back, the left is higher than the right. If the front on the right is 2 1/4, the left is 2 3/4. Measuring at the back, the right would be 2 1/2 and the left would be 3.
  7. #6
    Chev's Avatar
    Join Date
    Jul 2011
    Posts
    Location
    Georgia
    Mower
    Cub Cadet Commercial
    It sounds like nothing is bent. With a full half inch discrepancy I would check to see if both blades are fully seated on the spindle.
  8. #7
    Join Date
    Aug 2011
    Posts
    94
    Location
    welshpool
    Mower
    MTD - Yard-Man
    A bent blade is the most common cause of uneven cutting but a unleval deck is also a cause
  9. #8
    Join Date
    Aug 2011
    Posts
    Location
    Jacksonville3
    Mower
    Z-Beast commercial zero turn
    We had the same problem with our Cub Cadet. Well, that was just one of the problems with the Cub Cadet. Let's just say we don't have it anymore because it was costing us a fortune--always in the shop.
    We told the people in the repair shop that the mower was cutting lower on the left side (several trips to the shop) but they never repaired the problem you describe...didn't know what caused it so couldn't fix it. All I can say is "Good Luck" to you with your Cub Cadet. Maybe the "Lawnmower Fairies" will help you out.
  10. #9
    Join Date
    Oct 2012
    Posts
    Location
    Iowa
    Mower
    Did you try measuring the blades with a rider on it?
  11. #10
    Join Date
    Oct 2010
    Posts
    Location
    North Carolina
    Mower
    How are you taking measuments ?
Similar Threads
  1. Vibration/Bouncing of transmission belt on Cub Cadet RZT50
    By brianholland in forum Cub Cadet Forum
    Last Post: 06-25-2017, 09:55 AM
  2. Hustler Grass Cutting Problem
    By Rageous in forum Hustler Forum
    Last Post: 08-22-2011, 09:31 AM
  3. rzt50 2009 problems
    By lourene in forum Cub Cadet Forum
    Last Post: 08-14-2011, 06:19 PM
  4. Uneven grass cutting
    By irishmike63 in forum Mower & Equipment Operation
    Last Post: 07-23-2011, 11:51 AM
  5. Uneven lawn
    By EverGreen in forum Lawn Care & Landscaping
    Last Post: 07-05-2010, 02:03 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
