Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Blowing fuses
  1. #1
    Join Date
    Aug 2011
    Posts
    5
    Location
    South Carolina
    Mower
    Blowing fuses
    Hello from a newbie! I'm here becuz I'm currently in the fuse blowing mode w/my Craftsman 24hp, 42" deck riding mower. Something is causing the 20 amp fuse for the mower deck/blades to blow quite frequently now. Fuses are for mowing 1.5 acres are getting expensive. Anyone have any ideas as to the cause of this?
    "fuse man" (for now)
    Sent from willieksc using LMF
  2.
  3. #2
    1,000 Post Club
    Briana's Avatar
    Join Date
    Jul 2010
    Posts
    1,550
    Location
    California
    Mower
    Looking to Buy :)
    Re: Blowing fuses
    Hey there - WELCOME to LMF!
    I moved your thread to the Small Engine & Mower Repair Forum.
  4. #3
    1,000 Post Club
    reddragon's Avatar
    Join Date
    Jun 2011
    Posts
    1,377
    Location
    southern oregon
    Mower
    little this...little that
    Re: Blowing fuses
    fuses blow because of shorts in a circuit.....something connected to that lead is shorting before it completes its proper circuit.....look at all your wiring for burnt insulation or nicks and cuts that can contact the metal on the engine or frame etc............can you take pictures of your wiring?
    '97 MURRAY 15.5hp TECUMSEH..42"...6SP............'04 TROY-BILT BRONCO....18.5 BRIGGS..42"...AUTO...CRUISE...
    '06 MTD YARD MACH...15.5 HP B&S...42"..6 SP ....'99 CRAFTSMAN...19.5 HP....42"...6SP
    '94 AYP KGRO...16HP B&S...42".....5SP ................'77 SEARS 18-6...18HP ONAN ...42"....6SP
    '98 CRAFTSMAN..17HP B&S ..42"...HYDRO............'93 MTD YARD MAN 18HP B&S ...42"....HYDRO
    '02 CRAFTSMAN LT1000.. 17HP B&S...42"..5SP.....'00 MTD 679..17.5 TECUMSEH...42"....7Sp
  5. #4
    Join Date
    Aug 2011
    Posts
    5
    Location
    South Carolina
    Mower
    Quote Originally Posted by reddragon
    Thanks for the reply, I started that process this afternoon for the easy to get to areas. I found one spot & taped it good, but it apparently wasn't the problem or the total problem. I'm now headed to the more difficult to access areas, i.e, underneath the engine. Thanks again.
  6. #5
    Join Date
    Aug 2011
    Posts
    Location
    Midwest
    Mower
    Re: Blowing fuses
    Is the fuse holder getting hot before it blows fuses?
  7. #6
    Join Date
    Aug 2011
    Posts
    5
    Location
    South Carolina
    Mower
    Re: Blowing fuses
    It's hard to tell if it's getting hot because of the electrical problem or from the ambient temp from the mower itself or outdoor temp. It is definitely hot when it blows, but not so hot I can't change it comfortably. I'm really wondering about the PTO on the mower. Is the PTO powered such that it could cause this? I'm obviously not a mower repair expert so I appreciate your willingness to help!
  8. #7
    1,000 Post Club
    reddragon's Avatar
    Join Date
    Jun 2011
    Posts
    1,377
    Location
    southern oregon
    Mower
    Re: Blowing fuses
    to go further...go head and give us the model /serial numbers of the mower and the model/serial numbers of the engine
  9. #8
    Join Date
    Oct 2010
    Posts
    90
    Location
    New Jersey
    Mower
    '03 scag tigercub
    Re: Blowing fuses
    Fuses will also blow from a high amperage load, meaning that if an electrical part starts to fail
    internally it uses more electrical current than its designed to thus snapping the fuse. Sometimes it will work for awhile and then snaps the fuse and sometimes it has a direct short like reddragon explained and blows instantly. Also check for dirty connections in this circuit I've seen dirty connections build a lot of
    resistance that the circuit gets so hot and blows the fuse. Next make sure there aren't any other circuits
    being protected by this same fuse too. they could be at fault too. Maybe the pto will get so bad that it will
    start blowing the fuse instantly then you'll know for sure.....cubby
  10. #9
    Join Date
    Oct 2010
    Posts
    243
    Location
    Mulvane Kansas
    Mower
    Re: Blowing fuses
    I'd disconnect the wiring to the clutch and see if it starts and runs through all functions without blowing a fuse. If everything works fine then the clutch is most likely bad. If the fuse does blow, I would unplug as many other features as possible then start up the mower and plug them back in one at a time till you find the culprit.
  11. #10
    Join Date
    Mar 2011
    Posts
    881
    Location
    Washington
    Mower
    honda 1031, cub cadet 2164, jacobsen park 30, simplicity
    Post Re: Blowing fuses
    All good advice. I'll chime in that I like to use a Dremel tool with a soft brass brush to clean up all of the terminals, make sure they are nice and tight, and put either a dab of dielectric grease or a dab of No-alox or equivalent on it before reassembly. A q-tip makes a handy applicator in case you can't reach easily.
Similar Threads
  1. Engine Exhaust blowing white smoke and oil.
    By Jeffvador in forum Troy-Bilt Forum
    Last Post: 12-18-2011, 07:05 PM
  2. Briggs & Stratton engine 675 series blowing smoke and oil
    By slash8789 in forum Briggs & Stratton Forum
    Last Post: 07-25-2011, 10:49 PM
  3. Replies: 3
    Last Post: 07-18-2011, 09:15 PM
  4. Blowing gas
    By Patio in forum Small Engine & Mower Repair
    Last Post: 06-28-2011, 04:24 PM
  5. Benefit to Blowing or Waste of Gas?
    By AndyMan in forum Lawn Care & Landscaping
    Last Post: 11-29-2010, 05:32 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
