CUB CADET RUNNING VERY SLOW
I just found this posting about Cub Cadet transmition clutch issues and shimming SOLUTION from another site.
See below, does anyone know if this cheep fix really works out well?
Interesting!
My local dealer who quoted $600 to fix this problem. His solution was to replace the whole assembly. I finally spoke with someone at Cub Cadet tech support and they told me how to fix it wit $5 worth of parts!
The solution is to remove the frame cover (6 bolts) to get access to the top of the cluth assembly. The clutch assembly has a cover on on the top rear. If you remove this cover (3 bolts) you will see a bearing. The clearance between the outer race of this bearing and the cover (put straight edge against it shuold be 2/1000 - 7/1000. If it is not your clutch will slip. To fix it buy some $2 shims (washers). The part numbers are
736-3126 - Washer, flat, 1.25 x 1.8 x 0.005
736-3127 - Washer, flat, 1.25 x 1.8 x 0.010
736-3104 - Washer, flat, 1.25 x 1.8 x 0.015
736-3105 - Washer, flat, 1.25 x 1.8 x 0.020
736-3106 - Washer, flat, 1.25 x 1.8 x 0.025
736-3107 - Washer, flat, 1.25 x 1.8 x 0.062
Once you have these remove the bearing. Press on the forward pedal to help push it out and then pull it the of the way. I did this with a bent heavy paper clip. Insert the proper washers to get back within spec (2/1000 - 7/1000), insert the bearing and put the cover back on.
If the spacing is to small (< 2/1000) then the tractor may creep when idling in 1st gear. Other than that you shuold be in good shape!
I assume this will work on any cub cadet lawn tractor with auto-gear transmission.
