Results 1 to 2 of 2
  1. #1
    Join Date
    Aug 2011
    cub cadet wont start plese help
    I have a sltx 1054 cub cadet with a 26 horse koehler courage engine. The mower only has 29 hours on it. Went to start it today there was a pop when starting like it was going to turn over then didnt. It cranks but wont turn over. Gas is getting to plugs, air filter is clean, tried new plugs still nothing. Just wondered if anyone has any other ideas Id appreciate it. Would take it in but cant really go that long with out one since they are backed up a couple weeks.
    Thanks again!
  3. #2
    reynoldston's Avatar
    Join Date
    May 2011
    Ferris, John Deere, Wheel Horse, Toro,
    Re: cub cadet wont start plese help
    check for spark with plugs in engine. buy a spark tester of a auto parts supply store, run about 5$. This is just a starting point for diagnosing the problem. spark, fuel, compression, timing and it will run.
Similar Threads
  1. mower wont start
    By ffsmith in forum Small Engine & Mower Repair
    Last Post: 02-17-2012, 09:19 AM
  2. JD L140 wont start
    By JustinTractor in forum John Deere Forum
    Last Post: 06-27-2011, 03:45 PM
  3. rer wont start
    By jeremy in forum Small Engine & Mower Repair
    Last Post: 06-11-2011, 12:31 PM
  4. wont start
    By bill reid in forum Toro/Wheelhorse Forum
    Last Post: 05-26-2011, 02:25 PM
  5. craftsman wont start
    By greebas in forum Craftsman Forum
    Last Post: 04-28-2011, 05:39 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
