Engine puzzled
keys1967
I have a Hustler Sport mower and it will not start. I have replaced the kill switch under the seat and replaced the spark plugs. It spins over but does not fire. it seems like there is another safety switch that is preventing the mower from starting.
BlazNT
The seat switch is not in the starting circuit. The transmission in neutral, PTO off and brake on are.
BlazNT
Remove the engine cover and remove the kill wire from the coils. If you get spark then one of the safety switches is not working correctly.
