- Nov 29, 2014
- Threads
- 64
- 24,702
Thanks Bert. I'll check that out.
Here's the meter reading I get from the battery posts and the wires from from the alternator.
https://www.youtube.com/watch?v=24HuUJiUbwE
Also, I put a test light on the two wires from from the Alt., and it lights up on both wires. One side lights up much brighter than the other.
UPDATE: Bert, I did the test like you said, and didn't get continuity from either way, when touching just the pin and the connection. But, with the pin through the red wire, about an inch back from the diode, I did get continuity when I touched the other lead. Even when I switched them.
BTW, I get juice to the negative side of the battery, ONLY when the engine is running.
With that said, it can only be the stater or diode, right?
No continuity between the pin and the plug in either direction says the diode is open circuit.
This should mean you get no juice back to the battery at all..
In any case, the diode is stuffed.
You can solder in a new one or replace the whole stator.
Soldering is a messy job because Briggs soldered it to the pin in the plug.
So you need GM pin tool to remove the red wire from the plug then desolder the diode at both ends and solder in a new one then refit the pin into the plug.
Works about 25% of the time.
Usually I end up cutting off both plugs and fitting new T shaped 2 pin spade plugs with the diode soldered in a fair way back up the wire.
In all honesty a new stator complete with a real full wave rectifier is a much better way to go even if it is a lot more expensive.
