Golf Pro 61
- May 27, 2018
- Threads
- 2
- 9
I am having trouble keeping the clutch engaged. I know that I now need to see how many amps the clutch is pulling but do not know how many it should be? I do know the breaker is 20 amp so I would guess it has to be below that but would like to know the real amount. If I do not have a DC Amp meter could I put in a in line fuse and and just see what amp fuses it blows? cheaper than buying a meter I figure.
Also the hot wire going to the clutch should be the blue one correct?
I have done these things.
1. Had the battery tested (good) 12.6 volt off 13.65 Volt running.
2. Replaced the PTO switch.
3. Tested the Ohms on the clutch 3.2 and tested no dead shorts.
4. Set he air gap to .016 then also tighten 1/4 turn 2 times.
Snapper mower 18 hp 44" cut clutch # 5023100sm
Thanks
Thanks
