yardman yard bug 9hp
popwalker
Just got this Yardman Bug 9hp and I can't get to shift into gear. It's like new all belts are good. Any Ideas?????
I see you are starting a new thread with the same problem. You would probably get some help if you told us the model and serial numbers of your bug. If you expect us to try to find your unit without these, I doubt if we want to go to all that trouble, when you could easier walk out to your garage and look them up. If you help us we might be able to help you. Also, having two threads is going to be confusing.
Catherine
LawnWorld Support
Staff member
:welcome:
Welcome to the forum!
Hopefully, you'll get some answers in your other thread.
