Results 1 to 5 of 5
  1. #1
    Join Date
    Sep 2016
    Posts
    4
    Location
    Texas
    Mower
    honda hrx217hxa
    HRX217HXA motor revs up good, sputters down, then revs up again
    Hi, my mower will run great for 10 seconds, then sputter down, cough a little black smoke, then rev up again, run good for 10 seconds, then repeats. The old carb was doing this, so I put a new carb on yesterday. The mower is still doing this revving up, sputtering down, revving up again, over and over. Does the carb need adjusting? other issue?
  2.
  3. #2
    2,500 Post Club
    Boobala's Avatar
    Join Date
    Feb 2015
    Posts
    4,550
    Location
    Central Fl. about 2 hours from DAYTONA !
    Mower
    Murray Select 21 H.P. 46" ( 2004 )
    Re: HRX217HXA motor revs up good, sputters down, then revs up again
    Sounds like you might have a "gremlin" in the fuel system, MY procedure, is to THOROUGHLY clean the ENTIRE fuel system, inside of gas-tank= IMMACULATE, fuel lines, and filter replaced, fuel shut-off valve, SUPER cleaning OR replaced, THEN either an EXCEPTIONAL cleaning or O/H of the carb. one final step, be absolutely sure your gas-can ( the one you use to fill the machine(s) ... double-triple check that too, I've O/H carbs for folks, only to find out their recurring problem was caused by &@#$%$#@ in their gas-can, something usually over-looked. ..
    Mower : Murray Select 46 " deck
    Model : 465306X8A
    Serial # : 733781D027
    Date of Mfg. : 2003/12/03
    Engine : Briggs & Stratton
    I/C V Twin
    21 H.P.
    Model : 4045A7
    Type : 0211 E1
    Code : 031104YG
    Family YBSXS . 7242VF 22844
  4. #3
    Join Date
    Sep 2016
    Posts
    4
    Location
    Texas
    Mower
    honda hrx217hxa
    Can you describe the procedure and what chemicals you use to clean the gas tank, carb, and fuel lines?
  5. #4
    Join Date
    Aug 2013
    Posts
    Location
    Maryland
    Mower
    Is this a auto choke or a manual choke.
    To remove the gas tank take the 3 10mm nuts from the starter . Remove the starter then the gas tank.
    Yo do not need any chemicals for the tank. A good washing with water and let it dry.
    If you replaced the carburetor you should be able to also replace or clean the lines.
  6. #5
    Join Date
    Aug 2016
    Posts
    11
    Location
    United States of America - Terra
    Mower
    At risk of being captain obvious, you have checked the basics as well right? Air Filter / Spark Plug / Fresh Gas...
Similar Threads
  1. Revs too high
    By hrdman2luv in forum Briggs & Stratton Forum
    Last Post: 04-11-2018, 06:30 AM
  2. revs but misses - ?
    By smicksburg in forum Mower & Equipment Operation
    Last Post: 04-04-2017, 05:23 PM
  3. Robin revs up and down? Please help!
    By ThatGuyYouKnow in forum Small Engine & Mower Repair
    Last Post: 04-17-2016, 05:56 AM
  4. Engine Snapper Rear Engine-Motor revs up and down
    By jimcahoe in forum Snapper Forum
    Last Post: 08-19-2014, 12:55 PM
  5. still over revs
    By bigriggs in forum Small Engine & Mower Repair
    Last Post: 08-11-2013, 11:15 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
