Kohler Courage Twin Cam Startup Noise...
JonnyBlaze
I have two 20hp SV600's that make this exact same kind of grinding noise at startup. What is it? One only has 4 hours on it.
Also, this one pops out the exhaust once when I turn it off. That means it's running rich, right? What do I do?
https://youtu.be/BgWd2-BS85I
BlazNT
Question number one. Starter.
Question number 2. Did you move the throttle back to 3/4 before you turned it off? It is not unnormal for Kohlers to pop if not at 3/4 throttle and all settled in.
JonnyBlaze
Is the starter bad?
I think so. Cant be sure.
BlazNT
Is the starter bad?
If it is starting then the starter is fine. I have found a a lot (hate to say a lot) of Kohlers make a grinding noise when you start them.
JonnyBlaze
Yeah, that explains why the one with 4 hours does it too.
