Results 1 to 3 of 3
  1. #1
    Join Date
    May 2016
    Posts
    Location
    New York
    Mower
    Black and Decker
    Troy-bilt TB30R Deck removal tips?
    I wanted to remove the deck from my new Troy-Bilt TB30R to clean and change the blade.
    In the manual there are steps listed but the manual doesn't mention removing the belt guide/guard bar.
    It seems to me that it would necessary to do so to get enough slack to remove the belt form the PTO.
    Has any one doe this successfully?
    Is the elt guide/guard bar hard to get back on?
    The manual reads:
    1. Place the PTO lever in the disengaged (OFF) position and engage the parking brake.
    2. Lower the deck by moving the deck lift lever into the bottom notch on the right fender.
    3. Remove the bow-tie cotter pin (a) and flat washer (b) from the deck lift assembly, and retain for reinstallation later.
    4. Remove the belt from around the tractor’s PTO pulley.
    5. Remove the remaining bow-tie cotter pins (a) securing the deck to the riding mower.
    Note: When reassembling, the bow-tie clips (a) should be re-installed from the top down.
    6. Unplug the wire pigtail from the deck switch.
    7. Move the deck lift lever into the top notch on the right fender to raise the deck lift arms up and out of the way.
    8. Carefully remove the PTO cable from the rear of the cutting deck. Remove the spring from the deck idler bracket.
    Thanks in advance for any advice from someone who has remove the deck on this model.
  2.
  3. #2
    Join Date
    Nov 2014
    Posts
    8,327
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    Re: Troy-bilt TB30R Deck removal tips?
    When you take all of the links off the deck will move forward enough to remove the belt from the engine.
    You leave the guards on the deck there till it is out.
    Leave the PTO cable on there till last and slide the deck out a little to get easier access to it.
    Usually you can roll the belt off past the keepers on the engine pulley with little more than a bit of thumb pressure on them to spring them away from the pulley.
  4. #3
    Join Date
    May 2016
    Posts
    Location
    New York
    Mower
    Black and Decker
    Quote Originally Posted by bertsmobile1 View Post
    Thanks for your reply.
    I will try again this weekend!
Similar Threads
  1. Mower deck Any tips on deck removal, belt and bearing replacement on an LTR 180?
    By Kltxag82 in forum John Deere Forum
    Last Post: 05-15-2018, 03:27 PM
  2. Troy-bilt TB30R Deck removal tips?
    By bdcs64 in forum Troy-Bilt Forum
    Last Post: 11-15-2017, 09:19 PM
  3. Troy-Bilt TB30R brakes and clutch ajustment
    By Caretaker99 in forum Small Engine & Mower Repair
    Last Post: 04-03-2017, 05:02 AM
  4. Repairs Troy Bilt Mustang 42 Deck Removal
    By Mustang Atlanta in forum Troy-Bilt Forum
    Last Post: 05-14-2015, 11:50 PM
  5. battery rremoval -troy bilt TB30R riding mower
    By birdie in forum Small Engine & Mower Repair
    Last Post: 10-29-2014, 10:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
