Results 1 to 9 of 9
  1. #1
    Join Date
    Nov 2017
    Posts
    17
    Location
    Pennsylvania
    Mower
    Club Cadet RZT S42
    High Speed Idle Adjustment
    I have a Kohler Command 7000 KT725(2017) and need to check it's high speed at 3600 rpm.
    How do adjust since there is no high speed idle screw? See bottom pic.
    I planning to use a digital rpm meter
  2.
  3. #2
    Join Date
    Nov 2014
    Posts
    8,327
    Location
    Australia
    Mower
    Victa slashers & Push , Rover Rancher II's, Cox ( several ) & White LT120 + GT 200
    Re: High Speed Idle Adjustment
    The term high idle is a bit confusing.
    The bolt K is what is used to adjust the high speed when the engine is not under load , ie idleing
  4. #3
    1,000 Post Club
    EngineMan's Avatar
    Join Date
    Jun 2012
    Posts
    2,010
    Location
    South Wales UK
    Mower
    No mowers
    High speed is the MAX set at 3600 rpm
    "Information/Knowledge not shared will be lost for ever, I will give freely any information that will help you out, you don't have to take it, that is up to you...! and the word "thank you" will not cost you anything, so be nice sometimes and use it"
  5. #4
    Join Date
    Nov 2017
    Posts
    17
    Location
    Pennsylvania
    Mower
    Club Cadet RZT S42
    I don't see so called bolt 'K' for setting it to 3600rpm. Where is it?
    Can someone circle the area that needs to adjusted? Thanks.
  6. #5
    BlazNT's Avatar
    Join Date
    Apr 2012
    Posts
    5,408
    Location
    Missouri
    Mower
    RZ5424
    To adjust top speed you loosen bolt circled in green and with the throttle set to fast or rabbit move cable in or out till the desired RPM is reached. Then tighten bolt circled in green down. Take care to not over rev. Good things do not come from over revved engines.
    Chuck
    We Do Not Stop Playing When We Grow Old
    We Grow Old If We Stop Playing
  7. #6
    Join Date
    Nov 2017
    Posts
    17
    Location
    Pennsylvania
    Mower
    Club Cadet RZT S42
    Quote Originally Posted by BlazNT View Post
    Thanks. Last year the mower went to the dealer for a choke adjustment (under warranty), because in choke mode the butterfly wasn't closed fully. They adjusted it and it almost starts on the 1st crank.
    This mowing season, the fast mode seems to be under powered.
    I will test with a digital tachometer for 3600rpm before proceeding.
    Thanks again.
  8. #7
    Join Date
    Nov 2017
    Posts
    17
    Location
    Pennsylvania
    Mower
    Club Cadet RZT S42
    Bought chrome colored nail polish and painted one plastic cooling fin so the digital tachometer had a reflective surface to read from. ( Removed the cooling shroud to make the measurement ) At fast idle mode it read 3400 rpm, I made no adjustment since the engine only has 23hrs. Do you think I should have adjust it to 3600 rpm?
  9. #8
    Join Date
    May 2010
    Posts
    5,201
    Location
    Illinois
    Mower
    kioti/rhino finish mower
    I would call it close enough.
    ILLINOIS ENGINE, BEECHER CITY, IL
    BRIGGS AND STRATTON MST (MASTER SERVICE TECHNICIAN)
    Sales and Service for Dolmar/Makita, Poulan, Briggs and Stratton, Kohler, Lauson(Tecumseh, LCT), Brute, Honda, Subaru
    Warranty service for MTD, Murray, Karcher, Earthquake, Yamaha engines, American Landmaster, Worx, Rockwell Tools, Great Lakes Technologies products(Wen, CZ), Efco, Generac portable/DR power and others.
  10. #9
    Join Date
    Nov 2017
    Posts
    17
    Location
    Pennsylvania
    Mower
    Club Cadet RZT S42
    Thanks, I will leave it alone for now and remeasure at 100hrs.
Similar Threads
  1. FX850V high idle issues
    By krmaddock in forum Kawasaki Engine Forum
    Last Post: 08-10-2017, 09:54 AM
  2. idle way too high
    By brian400ex in forum Briggs & Stratton Forum
    Last Post: 09-07-2016, 07:04 PM
  3. Exmark will not maintain high idle
    By Tank6102 in forum Exmark Forum
    Last Post: 05-13-2013, 01:00 PM
  4. Troybilt tb230 high idle
    By BFSGREG in forum Troy-Bilt Forum
    Last Post: 03-18-2013, 05:38 PM
  5. LawnBoy high idle
    By doublel in forum Small Engine & Mower Repair
    Last Post: 04-05-2011, 10:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
